It is currently Mon Jun 03, 2024 9:59 pm
[ 5 posts ] |
13 hp surface drive build.
dcheff
Ive been lurking around this forum on and off for a while now. I built a mud motor three years ago with my brother and I just decided to build another one. This is a 13 hp honda surface drive. I will be using it as a permanent mounted engine on a small duck hunting / fishing pontoon. I decided to go with a 3/4 x3/8 inch cog belt to get rid of the vibration chain makes and to kill the problems we had with a vbelt setup. I made this all in my shop in my spare time. I was going to make it out of aluminum but my tig welder is down at this time so I made it out of steel. any thoughts on it? just felt like posting pictures somewhere, im pretty proud of it but still working on it and I am sure I will be redoing things. I had to completely manufacture a centrifugal clutch as I could not find one made for this..
Sun Apr 03, 2016 9:46 am |
Cwb7
Re: 13 hp surface drive build.
I'd love to do the same! How much did it cost you to build?
Thu Apr 07, 2016 3:01 pm |
dcheff
ill list what I can remember
seals x4 20 bearings x5 50 prop 200 belt and pulleys about 100 the rest were scraps I had around the shop. and probably another 50 bucks in miscellaneous supplies
I am machining a new pulley for it tomorrow to get the belt spacing a bit better (more room where the tensioner pulley presses on the belt. I originally planned on making this out of aluminum, but at the time I did not have my tig welder hooked up as I just moved to a new shop. Now I just need to get some controls so I can mount it on the boat to test the design then I will make it out of aluminum.
Tue Apr 12, 2016 7:49 pm |
BERNIE255
Joined: Sun Jun 16, 2013 4:43 pm Posts: 1381 Location: Avoyelles Parish/ Marksville LA
Put a skeg on underneath the shaft
Tue Apr 12, 2016 9:24 pm |
dcheff
It has one now, ill post a few new pics tomorrow
Sent from my SM-N920P using Tapatalk
Tue Apr 12, 2016 9:39 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 54 guests |
