| I suck at camo stencils! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=17&t=13228 |
| Author: | autogateman [ Thu Oct 21, 2010 3:04 pm ] |
| Post subject: | I suck at camo stencils! |
so i got the great idea last night to camo stencil my boat. well, it appears that my faded green boat is now faded green, smeared bark, and fuzzy grass. still debating on whether i like it better like this or with the ugly faded paint. so how the hell are you supposed to keep the stencil flat on the sides when you have the 'crease' from front to back? I dunno, ill prolly just leave it like this till next year |
| Author: | cmelvin [ Thu Oct 21, 2010 3:28 pm ] |
| Post subject: | Re: I suck at camo stencils! |
your right you do suck |
| Author: | dog walker [ Thu Oct 21, 2010 3:43 pm ] |
Don't lie it sucks. Maybe if you tried harder it would look better. |
| Author: | meterman3 [ Thu Oct 21, 2010 3:53 pm ] |
yep it sucks but the stuff under the tires came out good lol |
| Author: | Sando [ Thu Oct 21, 2010 4:24 pm ] |
Its really not that bad man. |
| Author: | autogateman [ Thu Oct 21, 2010 4:46 pm ] |
| Author: | Team Camo [ Thu Oct 21, 2010 5:44 pm ] |
Yep, ya paint like "him" too. |
| Author: | Bream Busta [ Thu Oct 21, 2010 7:15 pm ] |
Not that bad for your first time...ive seen alot worse. |
| Author: | BASSMASTER [ Thu Oct 21, 2010 7:19 pm ] |
holy shat .. look at that grab bar .. looks fat guy friendly! |
| Author: | godevil16 [ Thu Oct 21, 2010 7:21 pm ] |
man id let u do mine lol better than i would do im not a painter |
| Author: | SmokeEater829 [ Thu Oct 21, 2010 7:27 pm ] |
Its not bad. But, when I did my boat, I made a cardboard frame for my stencils. About 2 inches around the stencil helped me make the bend around the crimp. |
| Author: | autogateman [ Thu Oct 21, 2010 7:28 pm ] |
| Author: | autogateman [ Thu Oct 21, 2010 7:41 pm ] |
| Author: | Bream Busta [ Thu Oct 21, 2010 7:45 pm ] |
| Author: | Pooh Bear [ Thu Oct 21, 2010 7:48 pm ] |
That LT is pimp tight with that Custom Air Cleaner...... |
| Author: | mudbutt2269 [ Fri Oct 22, 2010 8:56 am ] |
i did mine drinking with no stencil i kinda felt like picasso until the next morning win i looked at itmy boat.JPG |
| Author: | BROOKS [ Fri Oct 22, 2010 1:19 pm ] |
Now that you gots yore boathull painted and lookin' good ...... Start the repairs on the barn ....... |
| Author: | dog walker [ Fri Oct 22, 2010 2:12 pm ] |
If you did a search here on the MMT you could have found all sorts of usefull tips that would have helped with your end results,just saying. |
| Author: | autogateman [ Fri Oct 22, 2010 2:46 pm ] |
dw, i looked all over and couldnt really find any tips on how to do it correctly. i dunno, im also not very good at the search feature |
| Author: | shooter [ Fri Oct 22, 2010 3:03 pm ] |
| Author: | BASSMASTER [ Fri Oct 22, 2010 3:08 pm ] |
i'd add more hot pink.. those bright color like lime green, or silver really work good in the marsh! TRUST ME! |
| Author: | dog walker [ Fri Oct 22, 2010 3:09 pm ] |
deadbird8 is the "man" when it comes to camo stencils,Poker is not bad either. Check them out. |
| Author: | Woodiebuster [ Fri Oct 22, 2010 8:22 pm ] |
Jus10 #2, I would take a small brush and flat black paint and put twigs an limbs over that grass in places. |
| Author: | med [ Thu Oct 28, 2010 1:49 am ] |
use stencil adhesive. can be found at a craft store. you just mist the back of the stencil. works good just dont use too much. |
| Author: | UNCLE-J [ Thu Oct 28, 2010 6:05 am ] |
| Author: | Gigafowl [ Thu Oct 28, 2010 6:55 am ] |
Just go back and add another layer or two of accent colors.... Needs more depth... Just a tip though - balancing the artist's alchol content at the time is the real key - too little, no creativity - too much, paint everywhere - LOL links - from search viewtopic.php?f=2&t=8242&hilit=paint viewtopic.php?f=4&t=1106&hilit=paint viewtopic.php?f=4&t=8103&hilit=rattle+can |
| Author: | bfenn [ Sun Oct 31, 2010 6:06 am ] |
I used the same stencils on my old boat, what I did was remove the motor, took the boat off the trailer, and flipped it over. Then I taped the stencil to the bottom edge of boat, pressed it down to the crimp sprayed, then press on the other side of the crimp, and spray. After about three or four times stop and let the paint on the stencil dry, the start again this prevents the excess paint from smearing on the boat. The paint will build up on the stencil so thick that you will have to stop and crack it and remove from stencil. It's a lot of work but wanted it to look good. P.S. It's not that bad to go through all the trouble with duck season here, but I would paint the inside it is much easier than the sides. |
| Author: | nmorel87 [ Tue Dec 14, 2010 8:24 pm ] |
[quote="med"]use stencil adhesive. can be found at a craft store. you just mist the back of the stencil. works good just dont use too much. [what type of stencil adhesive |
| Author: | rickjames [ Wed Jan 05, 2011 3:38 pm ] |
should have called i would have given you some camowrap |
| Author: | BabyMatt [ Wed Jan 05, 2011 4:32 pm ] |
I find the way I do it is better than stencils. I use real leaves. |
| Author: | marshmaster [ Thu Jan 06, 2011 8:55 pm ] |
Looks good from my house Oh and x2 on deadbird and his painting skills |
| Author: | deadbird8 [ Fri Jan 28, 2011 9:38 pm ] |
I used a light coat of 3M general purpose adheasive on the back- same concept as what Med posted above with the stencil adheasive. Only on the top layer though to make it crisp, the other layers I used a bent clothes hanger and spray whats flat against the boat. |
| Author: | TinySack [ Wed Mar 23, 2011 4:46 am ] |
any of you guys used the nat gear stencil on yalls hulls? |
