| Summer Project - First Rig Rebuild http://mudmotortalk.com/mmt_v2/viewtopic.php?f=17&t=44586 |
| Author: | Parker Knox [ Fri Aug 23, 2013 2:42 pm ] |
| Post subject: | Summer Project - First Rig Rebuild |
It has taken us almost 2 months to complete the project. If only work was an option instead of a necessity... Enjoy |
| Author: | Parker Knox [ Fri Aug 23, 2013 2:47 pm ] |
| Post subject: | Re: Summer Project - First Rig Rebuild |
Next... |
| Author: | Parker Knox [ Fri Aug 23, 2013 2:50 pm ] |
More |
| Author: | krogers [ Fri Aug 23, 2013 2:52 pm ] |
What make boat? I have a 14 x 4 horizon and it looks identical to that. |
| Author: | Parker Knox [ Fri Aug 23, 2013 2:52 pm ] |
More.... |
| Author: | Parker Knox [ Fri Aug 23, 2013 2:55 pm ] |
It's a Nova Jon Moreeeee..... |
| Author: | Parker Knox [ Fri Aug 23, 2013 2:59 pm ] |
| Author: | krogers [ Fri Aug 23, 2013 3:00 pm ] |
I gotcha, did it have benches? Looks good btw, just in time too. |
| Author: | Parker Knox [ Fri Aug 23, 2013 3:01 pm ] |
We're putting her on the water this weekend - I will be sure to post some pics of the rig in action |
| Author: | CJB [ Fri Aug 23, 2013 3:42 pm ] |
Good thing you camo'd the entire bottom of the boat...the ducks will NEVER see you now |
| Author: | naj [ Fri Aug 23, 2013 3:57 pm ] |
| Author: | dillakilla12 [ Sat Aug 24, 2013 7:22 am ] |
Good looking rig! Sent from my SCH-I605 using Tapatalk 4 |
| Author: | slingshot [ Sat Aug 24, 2013 3:23 pm ] |
Like the camo. |
| Author: | Basher 183 [ Wed Aug 28, 2013 2:07 pm ] |
Hey What did you use for lights? That is last thing I have to buy for my summer rebuild is running lights. I have some cheap Blazer 55 watt halogen's and I am thinking of changing bulb to 100's. I ran 14 ga wire from my switch panel thinking I would use LED, but those are expensive. Seems like most of the lights the boat guys sell are about 6000 lumens. Boat looks good. Mine is just getting done at the welder so it should be camo by Sunday. |
| Author: | Parker Knox [ Sun Sep 01, 2013 2:49 pm ] |
We're pumping out 7200 lumens. Take your cheap KC lights and install a backer plate, halogen bulb, and run new 14 gauge wire and you're set. It'll set you back $15? |
| Author: | Basher 183 [ Tue Oct 08, 2013 1:38 pm ] |
| Author: | Westi [ Tue Oct 08, 2013 2:30 pm ] |
| Author: | Westi [ Tue Oct 08, 2013 2:31 pm ] |
Btw, nice work on your project. Looks like you spent a good deal of time on it. |
| Author: | SETx Longtail [ Wed Oct 09, 2013 7:37 pm ] |
Looks like a VERY similar rig to mine. I'd like to do this kind of overhaul next year on mine. What did you use for the flooring? I'm also taking the center bench out of mine... The ribs on my hull are DEEP though, going to take plywood or something and put down between the ribs so they don't stick up too badly. Really liking the big box too. |
| Author: | jc [ Thu Oct 10, 2013 5:51 pm ] |
Thats a good looking rig. I really like the camo job. |
| Author: | coupe1975 [ Thu Oct 10, 2013 6:57 pm ] |
Good job on the revamp |
| Author: | Parker Knox [ Fri Oct 11, 2013 10:32 am ] |
Thanks guys. SETx, we set 3/4" black foam in the bottom first, then added the diamond plate shop mat foam to the top. All material weights less than 10lbs and was a very inexpensive addition. All pieces were attached with contact cement. Also, we eliminated the horizontal ribs in the floor of the boat by building the mats up to the top of these ribs. It's very nice not tripping over them anymore! |
| Author: | bbb [ Fri Oct 11, 2013 11:19 am ] |
Any thoughts on putting the gun box down the middle instead of on the side? That way it could double as seats. |
| Author: | banded-mallard [ Tue Oct 22, 2013 12:07 pm ] |
