I see someone..... http://mudmotortalk.com/mmt_v2/viewtopic.php?f=17&t=65 |
Author: | Mudhole [ Thu Jan 15, 2009 7:47 am ] |
Post subject: | I see someone..... |
Has figured out how to post pics on dis new board, damned ifn I can!!!!!! |
Author: | LaBirdman [ Thu Jan 15, 2009 8:15 am ] |
Post subject: | Re: I see someone..... |
Posted mine just like the old site. Photobucket img code copy then paste in your message. |
Author: | hatchie hunter [ Thu Jan 15, 2009 10:09 am ] |
That's what i did too |
Author: | 50fps [ Thu Jan 15, 2009 2:38 pm ] |
Author: | Mudhole [ Fri Jan 16, 2009 8:21 am ] |
Yea I get the same thing! Heck, I can't even figure out to fix my avatar, it's square and needs to be rectangle!! See hows it be all scrunched up??? |
Author: | hatchie hunter [ Fri Jan 16, 2009 8:26 am ] |
go to the avatar edit thing and where you can put in numbers put 150x100..i think that should fix it. |
Author: | Gatorpoint [ Fri Jan 16, 2009 9:03 am ] |
Yeah under the edit avatar section you can adjust the width by changing the first number. Cant be under 100 or over 150. Find the width that makes it look the way you want it. |
Author: | Tony B [ Fri Jan 16, 2009 9:22 am ] |
The minimum avatar setting is 100 x 100 and the max is 150 x 100 |
Author: | harbday [ Fri Jan 16, 2009 11:37 am ] |
Im also getting the same error message from photobucket. |
Author: | J_Ho [ Fri Jan 16, 2009 3:23 pm ] |
Mine says its too big!? 146.18klb whatever that means - Never mind ![]() |
Author: | basinhunter [ Sun Jan 18, 2009 3:51 pm ] |
So Tony, I got the avatar size thing working but I can't post pictures. I keep getting this "It was not possible to determine the dimensions of the image" So what do I need to do to post pics? |
Author: | LaBirdman [ Sun Jan 18, 2009 4:01 pm ] |
What I had to do BH is copy and past the direct link in photobucket. |
Author: | basinhunter [ Mon Jan 19, 2009 8:12 am ] |
Author: | LaBirdman [ Mon Jan 19, 2009 8:25 am ] |
Minor glitz in the system Tony gonna have to fix. Edited a post the other day with pics and then pics couldn't post. Unable to determine size. So don't go editing nothin'. ![]() ![]() |
Author: | basinhunter [ Mon Jan 19, 2009 4:41 pm ] |
Tony B where u at???????????????? |
