| GatorGlide Videos/Pictures (post em here) http://mudmotortalk.com/mmt_v2/viewtopic.php?f=18&t=51656 |
| Author: | Will [ Fri Mar 21, 2014 5:02 am ] |
| Post subject: | GatorGlide Videos/Pictures (post em here) |
There are a few "hidden" videos of Gator Glide in action that are in other threads, with there being so many GG threads I think yall should post the videos/pictures here so more folks can see what it does like this one from 2ducks. https://www.youtube.com/watch?v=Wi5p5trH1_4 [youtube]https://www.youtube.com/watch?v=Wi5p5trH1_4[/youtube] I don't know why it won't imbed...? |
| Author: | OwenDickeson [ Fri Mar 21, 2014 8:03 am ] |
| Post subject: | Re: GatorGlide Videos/Pictures (post em here) |
| Author: | TPerkins [ Tue Mar 25, 2014 8:29 am ] |
| Author: | KENNEDY [ Sat Apr 05, 2014 10:55 pm ] |
That should be a Miller commercial on the outdoor channel! Sent from my iPhone using Tapatalk 2 |
| Author: | DeltaRunner [ Sat Apr 05, 2014 11:37 pm ] |
| Author: | txkingfisher [ Sun Apr 06, 2014 10:16 am ] |
MUD SLIDE! Because it was a few dollars cheaper. |
| Author: | coupe1975 [ Sun Apr 06, 2014 11:25 am ] |
I'm running GG G2 and love it |
| Author: | GatorDubea [ Sun Apr 06, 2014 11:36 am ] |
can you run this stuff on a ribbed bottom and notice a difference? |
| Author: | shotgunwilly1117 [ Sun Apr 06, 2014 12:22 pm ] |
Made a huge difference on mine and it's ribbed |
| Author: | GatorDubea [ Sun Apr 06, 2014 1:58 pm ] |
still turn good? |
| Author: | USCG4X4 [ Sun Apr 06, 2014 2:40 pm ] |
I have it on a riveted Jon boat with ribs and it works great. Sent from my iPhone using Tapatalk |
| Author: | coupe1975 [ Sun Apr 06, 2014 3:28 pm ] |
My crawdad is ribbed. After installing GG it made a huge difference. The ribbed bottom grabbed any type of vegetation before GG. After installation I can't hardly tell a difference between vegetation and open water. |
| Author: | GatorDubea [ Sun Apr 06, 2014 3:51 pm ] |
pick up any speed? |
| Author: | coupe1975 [ Sun Apr 06, 2014 4:22 pm ] |
Going off my phone cause I didn't have a GPS at the time I did it .. it shows I picked up a few. I'm in a longtail so speeds not really a factor but in the vegetation I damn sure did. It felt like a gained ten mph or so cause vegetation would just about stop me. Id recommend it on a ribbed boat for sure. It actually turns smoother. And rides the stumps better. I wish I would have videotaped what.I.put it through uesterdayrwith my son. Went through shit so thick with vegetation so thick you couldn't hardly see 10 feet ahead of the boat. Went through it at a idle with my son. Well worth it. |
| Author: | GatorDubea [ Sun Apr 06, 2014 4:31 pm ] |
is it roll on or spray on? |
| Author: | coupe1975 [ Sun Apr 06, 2014 5:00 pm ] |
Its roll on. Really simple to install and simple to touch up later if needed. There's no need to flip boat. Tape off sides of boatto make a straight line. Sand bottom to scuff it up no need to go to bare merely. Wipe down with acetone till clean. Roll on with small ⅛ nap roller. Let sit about 8 hours to dry enough to set on trailer. Let cure a week to fully cure before putting in water. Nothing to it. "FROG" makes it and sells it. Pm him or go to gatorglide.com to answer any other questions. Hope this helps |
| Author: | Frog [ Wed Aug 27, 2014 4:50 pm ] |
| Author: | North LA Hunter [ Wed Aug 27, 2014 7:09 pm ] |
| Author: | Frog [ Thu Aug 28, 2014 5:25 am ] |
| Author: | Will [ Thu Aug 28, 2014 6:02 am ] |
You wont be disappointed, unless you unhook it before it's in the water, that is.... As far as speed, you'll pick up speed in vegetation, but not really enough to notice in open water, reason is you have less hull drag on the veggies and the prop has more stuff to bite than open water. |
| Author: | TPerkins [ Fri Aug 29, 2014 7:55 am ] |
| Author: | Will [ Fri Aug 29, 2014 8:19 am ] |
That's just too damn slick for the trailer, yall gonna play hell loading that bitch up. haha Needs some good centering guides up front and an automatic bow latch now... |
| Author: | baron von [ Fri Aug 29, 2014 8:28 am ] |
a lot of the ramps I use don't have much slope - makes launching and recovery very easy - even by myself. My boat is a barge without it, it was a bear with it it's a breeze |
| Author: | Rstigler [ Fri Feb 13, 2015 11:50 am ] |
how do you choose how much is needed...I have a 14x42 with ribs..I have been considering this stuff and after these vids I'm pretty sure Im going to buy... Thanks |
| Author: | USCG4X4 [ Fri Feb 13, 2015 4:59 pm ] |
| Author: | Rstigler [ Sat Feb 14, 2015 10:55 am ] |
THANKS USCG |
| Author: | okiekiller [ Sat May 30, 2015 6:00 pm ] |
Would 1 gallon be enough for a 1954 excel? |
| Author: | Russ [ Tue Jun 09, 2015 9:30 pm ] |
Yes. Contact frog. Or go to the gg website. He will make sure you don't buy to much and you get enough. Call him, he's always answered or called back when I called. |
| Author: | BadBowtie [ Sat Sep 16, 2017 6:53 pm ] |
Bought the half gallon combo base/g2 kit for my 1848 Sent from my iPhone using Tapatalk |
| Author: | BadBowtie [ Tue Oct 03, 2017 2:37 pm ] |
viewtopic.php?f=4&t=71305 |
