It is currently Fri Feb 13, 2026 7:36 pm
Reply to topic  [ 20 posts ]
 PD Recovery Team
MMT Moderator
Post PD Recovery Team
Brad was on call yesterday willing to help out and always the first on scene.
http://www.youtube.com/watch?v=ic4yI5ROFDk
http://www.youtube.com/watch?v=DTV3Cd11AbE
http://www.youtube.com/watch?v=qr39h8BQHEw
Got two more coming so be sure to check back I'll be editing the post to add the others as they finish uploading.
All videos were taken with the I-Kam glasses...
GTB 1860 w/ 2019 GTR40XD-HO
Sun Apr 18, 2010 7:45 pm
Post Re: PD Recovery Team
If the chick would have taken her shirt off, then the boat would have weighed a little less... it would have came right off
GOOD JOB BRADS... Way to always be there...
There is NO reason for an Airboat to be STUCK on that.... Whats wrong with that thing?
Uncle J
Sun Apr 18, 2010 8:22 pm
MMT Moderator
Okay all three have been uploaded.
1. Brad pulling GaugeTheDuckDog off dry ground
2. Cory (Turbodrive) pulling Direct Drive Airboat out
3. Brad pulling Take'emgator out
Sun Apr 18, 2010 8:32 pm
Sun Apr 18, 2010 8:52 pm
Brad, after pulling out a couple heavy loads this past year I found that a 100' or more of rope is a must have. You had the right idea. Instead of just grinding away on your motor, pull up as close to the other boat as possible then with alot of slack get you a running start in reverse and jerk the boat out. Its easier just to go back and forth and with a 100' or more of rope and let your momentom do the work. You wont blow a hole in the side of your motor that way.
18x48 Charles Leonard / 36PD
Sun Apr 18, 2010 8:57 pm
MMT Moderator
Sun Apr 18, 2010 9:09 pm
well lets see its a ucking direct drive first of all with bare alumnium on the bottom and i didnt go fast over it. if i recall right im pretty sure i let off the gas when i hit the ground so of coarse i got hung up on the hump. i could of got off but Corey helped. Thanks
15' Panther 350DD 72x30 Florida Paddle Prop
Mon Apr 19, 2010 8:35 am
MMT Moderator
Mon Apr 19, 2010 8:40 am
Mon Apr 19, 2010 8:51 am
thanks
Mon Apr 19, 2010 8:53 am
Nice videos!
My motor doesn't have docking assistance, it has REVERSE!
Mon Apr 19, 2010 7:18 pm
See Josh should haven't sold that PD :mrgreen:
Cory you still running a 32PD and why would you not use your winch in the first situation? Snuggs seems you should start a towing business :lol:
Sat May 01, 2010 1:14 pm
Sat May 01, 2010 1:27 pm
I have to agree with Poker on his recovery technique
Sat May 01, 2010 3:32 pm
Sat May 01, 2010 4:36 pm
If you dont have a solid anchor its tough to winch out anything.
Sat May 01, 2010 5:50 pm
poker, even if you got boats together and motors dropped all the way down?
Corey, you suggest a bigger winch if i get one? that 2000lb isnt enough to budge?
Sat May 01, 2010 9:12 pm
Sat May 01, 2010 9:17 pm
Sat May 01, 2010 9:28 pm
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Sun May 02, 2010 5:00 am
cron
