It is currently Fri Feb 13, 2026 6:53 pm
Reply to topic  [ 2 posts ]
 PD Hydro trim
Post PD Hydro trim
Gotta replace the reservoir tank because it's leaking. Sounds like others have had the same problem. Any tricks I should know before replacing it? How do I bleed/re-prime the lines?
1860 Prodigy
Thu Mar 19, 2009 7:38 am
Post Re: PD Hydro trim
do you currently have the clear plastic tank or the black metal tank?
When i did mine I trimmed the motor down, undid the lines (leak a little when off) undid the tank put new tank on, make sure fluid is full on dip stick then trim it up and down several times to get the air out and was good to go
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Thu Mar 19, 2009 9:53 pm
