It is currently Thu Jul 17, 2025 6:52 pm
Reply to topic  [ 19 posts ]
 OD Green Paint
Post OD Green Paint
What's the best brand of paint and primer to use when painting a new hull?
I seen that a few people used duracoat just looking for some of yall opinions, thanks in advance.
35gtr on a 1854 Deep South Custom
1436 flat pushed by a 16 GDLT
Sat Apr 16, 2011 11:32 am
Post Re: OD Green Paint
Call Lou, he can fix you up...
http://www.lockstockbarrell.com/
If the Steel aint Flying the Birds aint Dying....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Sat Apr 16, 2011 12:43 pm
Duralux aluminum boat paint seems to be pretty popular. Only come's in one color, but it's pretty much an olive drab. Does not require a primer which is nice...
Sat Apr 16, 2011 12:50 pm
I called davidsons hardware in houma another have duck boat green,pero green, dead grass green and dark green, and its only $22 a gallon ,
Sat Apr 16, 2011 1:43 pm
Bayoublack...
The Duralux is a bit more expensive, but you do NOT have to Prime.. So, with that said, it takes half the time, and you save money on primer..
Sat Apr 16, 2011 1:47 pm
they said it was Duralux ,
Is all of duralux's paint the same or just one kind you dont have to prime?
Sat Apr 16, 2011 1:56 pm
They are all not the same..
You need Alum. Boat Green.
Sat Apr 16, 2011 2:08 pm
Is it a good color?, I want something not too dark but not too light
Sent from my Motorola_i1 using Tapatalk
Sat Apr 16, 2011 2:10 pm
How much paint does it take to paint a 1854 with two coats?
Sat Apr 16, 2011 2:22 pm
If I were you I would paint it tan. Tan is much much easier to hide than that old dark od green.
1648 Tracker 50 Merc
Team Topwater-Alabama
Sat Apr 16, 2011 2:28 pm
Sat Apr 16, 2011 2:49 pm
Im gonna spray it so it shouldnt to bad, talk think I should buff it out sand it with a palm sander?
Sat Apr 16, 2011 3:26 pm
You can clean with luma-brite. Then buy an etcher and u can skip the hard sanding.
Sat Apr 16, 2011 3:58 pm
http://www.nextag.com/bottompaint/m736/seller-html
That is the link on where you can get the Duralux.
They have only one color of the "Aluminum Boat Paint" which is a no-primer paint-and as they put it "with a vinyl type coating". Dark Green Only. This is the M736 that some boat builders use. Geaux used it I know.
Then they have three colors in the Camouflage paint- Dead Grass Green, Pirouge Green, and Duck Boat Drab. This paints requires a primer coat.
They have pretty good instructions on what to do to prep and best ways to paint.
You can click the links and see a color sample of all.
Good luck
Sat Apr 16, 2011 4:01 pm
1848 Prodigy
35 GTR
Sun Apr 17, 2011 8:55 am
Do any of yall know the radio of how much thinner to add to the alum boat green to spray it?
I gave up mud motors
Sat Apr 23, 2011 1:29 pm
Check their website. I want to say the instructions say it is not recommended to thin, but it tells you how and what to use if you want to do it anyway.
Sat Apr 23, 2011 1:32 pm
DO NOT USE THE PARKERS DUCK BOAT GREEN FROM CABELAS!!!!!! The finish is soo flat on my boat it resembles a green chalkboard. everything that touches the hull leaves a white scratch
Sat Apr 23, 2011 2:01 pm
When he said aluminum boat green, I was assuming he was talking about the duralux paint. If that ain't what you were talkin bout T-bub, disregard my previous post.
Sat Apr 23, 2011 2:06 pm
Users browsing this forum: No registered users and 120 guests
