It is currently Sat Feb 14, 2026 12:06 pm
Reply to topic  [ 11 posts ]
 water in belt housing
Post water in belt housing
i hosed off my gt last run and last time i started it it sprayed water out what seemed to be the clutch but after looking i noticed i had filled up the belt housing about 3-5 inches up. since theres no drain i know about and this will surely dry rot the belt how do yall get the water out of yall's?
17x54 custom CC with stage 3 GTR.
Wed May 20, 2009 7:50 pm
Post Re: water in belt housing
there should be a drain, on the front of the belt housing, if not jus pull the clutch cover off and crank up the motor, the belt will sling it out.
Wed May 20, 2009 7:59 pm
What GG said
Wed May 20, 2009 8:06 pm
would be super easy to drill and tap on the bottom if there isnt one on your housing.
Wed May 20, 2009 9:31 pm
use a small hose and siphon
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Thu May 21, 2009 7:31 am
Buy a PD and don't worry about it.
Thu May 21, 2009 9:31 am
WHAT STANCO SAID.
THAT WAY YOU HAVE A PERMANENT DRAIN W/O THE NEED TO OPEN THE DRIVE.
:evil:
IF IT FLY, IT DIES !!!!!!!!!!
Thu May 21, 2009 12:18 pm
17x48 extreme stage 2 GTR
Thu May 21, 2009 5:46 pm
Maybee you have an older model but my gt has a screw in da front to drain it out
Fri May 22, 2009 5:36 am
He has an older model
Fri May 22, 2009 5:41 am
Pulled my screw last nite, had about a cup of rainwater in belt housing. Keep my motor covered and that keeps most of the rain out :D
Ace
Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
Fri May 22, 2009 6:04 am
