It is currently Wed Jul 16, 2025 10:14 pm
Reply to topic  [ 9 posts ]
 Trim and Tach
Post Trim and Tach
i have a PD has anyone run their trim switch and tach up to their grab bar? Id like to have it there so I can trim the motor while facing forward. I really wouldnt mind having a trim switch on there and on the control panel. Is that possible?
The nation that makes great distinction between its scholars and warriors will have its thinking done by cowards and its fighting done by fools.-Thucydides
It is the Soldier that salutes the flag, Serves beneath the flag, Who's coffin is draped with the flag and allows the protestor to burn the flag.-Unknown
Greater love has no other than this that he lay down his life for his friends. John 15:13
Thu Aug 04, 2011 2:11 pm
Post Re: Trim and Tach
Yep, somebody posted about it a while back.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Aug 04, 2011 5:43 pm
I search it thanks
Thu Aug 04, 2011 6:04 pm
it can be done but you will need to use relays. their trim uses a ground to switch power back and forth. go to a boat salvage and find a old merc tilt and trim relay pack and you will be good to go. the only one out their that doesn't need a relay pack is the m.b. with the merc tilt trim unit.
Thu Aug 04, 2011 6:59 pm
Good info. thanks!
Sat Aug 06, 2011 9:02 am
I could be wrong but I don't think they use relays. Just a really heavy duty switch. Sportsman's Guide has a heavy duty outboard trim switch, like you put up front by the trolling motor, that a lot of people have been using with goog success. That way you can mount it on the handle right behind the twist throttle. Use the search feature because there was a good thread that covered this. I think it was Coastal's idea.
Sun Aug 07, 2011 3:30 am
if he is going to run two switches he will need a relay pack. u have to take away the ground from the other switch or he will have to grow a third arm. :lol: on my older engine i bought my merc trim relay pack at a boat salvage for 15 bucks and i also got the little trim switch off the cowling off of two motors and mounted a trim on the bow and one on the blower housing so i can trim up and use the mudbuddy side mounted lock system that way i don't have to reach foward to the tiller handle to lock it or unlock it on my new engine. on the new mudbuddys with the merc trim u don't need a relay pack u can mount as many trim switches as u want.
Sun Aug 07, 2011 6:51 am
Does it matter that I am running a PD? Also, any idea what the thread was called on this subject, I cant find it
Sun Aug 07, 2011 8:58 am
Take your pick.
search.php?keywords=trim+on+grab+bar&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Aug 07, 2011 9:12 am
Users browsing this forum: Google [Bot] and 84 guests
