Gauge
 Saltwater
I run a GD LT 23hp with a 1648 tracker. My question is what affect will the salty air and saltwater have on my boat if I take it hunting on the coast? I plan on hosing it down, corrosion Xing and WD40ing the heck out of it. Is there anything else I should do? What kind of rusting precautions do you take before and after a trip to the coast/saltwater.
_________________ Chairman South Texas Delta Waterfowl Chapter San Antonio, TX
Mon Oct 31, 2011 6:12 pm |
WestEndAngler
MMT Moderator
 Re: Saltwater
I just rinse mine
Mon Oct 31, 2011 6:15 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
 Re: Saltwater
The last 2 guys here that I know that are running godevils in this area spray them down with Corrosion X
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
Mon Oct 31, 2011 6:29 pm |
slingshot
 Re: Saltwater
Bro 99.99% of the time I run the salt all year fishin and huntin just a good washin will be fine with a silcone spray after. I have no rust.
_________________ 1542 stuck to a 27mini. She gone. 1746 with a modded 35 gdsd Capt Team total asalt
Tue Nov 01, 2011 4:28 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
 Re: Saltwater
With all that said, If you do run salt water and do not do maintanance on it afterwards then you will end up with one big pile of rusty shit! that probably won't run! I've seen a lot of out of towners run their rigs during opening season then throw it straigth into a boat shed. They come back for the second slpit and it literaly looks like a 10 yr old motor turning to dust!
Tue Nov 01, 2011 4:58 pm |
Gauge
 Re: Saltwater
Wed Nov 02, 2011 1:12 pm |
WestEndAngler
MMT Moderator
 Re: Saltwater
Wed Nov 02, 2011 1:15 pm |
Gauge
 Re: Saltwater
Thanks WestEnd!
Wed Nov 02, 2011 1:45 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
 Re: Saltwater
used motor oil mixed with wd 40 in a spray bottle. 25% oil to 75% wd 40 ratio. Buy the wd by the gallon. Will last a long time.
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Wed Nov 02, 2011 2:11 pm |
swampmonkey
 Re: Saltwater
Boeshield T-9 Rust & Corrosion Protectant Aerosol Spray, 12 oz - good but expensive.
had the crap in my throttle cable over the big freeze jan '10 & didn't have any problems & my friends had lock up....basically bath the engine w/ the shiot
_________________ Gator Tail GTR35 on a Go Devil 16x56
Wed Nov 02, 2011 3:56 pm |
Gauge
 Re: Saltwater
Is there anywhere on the engine you are not supposed to spray anti-corrosion spray??
Thu Nov 03, 2011 5:13 am |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 Re: Saltwater
I wouldn't spray it in the muffler.
_________________ 1850 & 36pd
Thu Nov 03, 2011 5:47 am |
MaXXis85
 Re: Saltwater
A good hose down and some WD40 works well. Like BB said, if you ignore it over time your going to have a mess.
Thu Nov 03, 2011 5:58 am |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
 Re: Saltwater
Corrosion-X is good on everything. Electrical, metal, u name it. U can also get the HD Corrosion-X. It goes on as a thick film that doesn't dry. It is the ultimate in protection, u just have to use a steam cleaner r alcohol to remove it. Did I say it never gets hard. I spray my big engines down with it on my offshore boat.
_________________ 18'x54"CC Hanko/ 36PD
Thu Nov 03, 2011 7:12 am |
swampmonkey
 Re: Saltwater
Thu Nov 03, 2011 9:21 am |
kibb
 Saltwater
Where y'all getting corrosion x locally?
Thu Nov 03, 2011 9:40 am |
pooldoo73
 Re: Saltwater
Big cans from academy.
Thu Nov 03, 2011 10:48 am |
Gauge
 Re: Saltwater
Thu Nov 03, 2011 12:05 pm |
coastal
Joined: Wed Jan 14, 2009 8:29 am Posts: 1890 Location: South TX
 Re: Saltwater
Give it a good rinse with fresh water and spray the entire engine.
[youtube]http://www.youtube.com/watch?v=yH5trE3tbdg[/youtube]
_________________ I will keep my gun's,freedom and money.You can keep your change!
Thu Nov 03, 2011 12:51 pm |
kibb
 Saltwater
Thu Nov 03, 2011 12:59 pm |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
 Re: Saltwater
I've been using Corrosion X in the red can for years. Lately I've found that it leaves a residue that can collect some dirt over time, especially when I spray it on my Mikuni carb . Anyone else seen this?
Thu Nov 03, 2011 7:07 pm |
