Re: Upgrading PD Trim Switch
I found the thread.
viewtopic.php?f=2&t=16413&hilit=PD+trim+switchSo, it seems the older hydraulic pumps need a switch that is fed current (either positive or negative, but I would assume it's positive in this application) and then just distributes that current down one of two lines depending on which button you press. Therefore they can use the transom switch because it has 3 wires for the different legs mentioned above. Is this right?
The switches for the new pumps need to be fed both positive & negative. Then those are distributed down two lines that go to the hydraulic motor. Which line is positive and which is negative is determined by whatever button you press. Is this correct?
How can you tell if you have the new or old hydraulic pump? I think mine is the old version. It looks like the one in the link above.
