It is currently Mon Jul 14, 2025 2:40 am
[ 6 posts ] |
centxhunter
Joined: Fri Jan 13, 2012 1:28 pm Posts: 357 Location: Austin, TX
 Motor Recommendation?
Looking for Motor recommendations for shallow river, gravel and rocky. In Central Texas we have a few rivers that can be explored if the water is running.
Long Tail vs. Short tail, any major advantage from a shallow water perspective? No mudding application (wish there was).
Mon Jan 16, 2012 8:54 am |
PaleoHuntr
Joined: Mon Feb 21, 2011 5:21 pm Posts: 1800 Location: Idaho Falls, ID
 Re: Motor Recommendation?
If your not running in any mud I would recommend an outboard with a jet foot.
_________________ 1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Mon Jan 16, 2012 11:33 am |
HUNT4DEER
Joined: Sun Jan 03, 2010 10:39 am Posts: 833 Location: DODGIN ROCKS ON THE RIVER OR CARS ON THE INTERSTATE
if you plan on a smaller boat ide go with a sd. when i say small boat i mean up to 17 foot with a smaller load. if you have to haul a ton o people then a big boat with a jet. i would never run a jet of the same hp as a sd. i wouldnt think jet until i needed 60 plus hp. for the money vs. proformance there is no way ide run a jet hp to hp vs. a sd. again it all has to do with the boat and load you need.
Fri Jan 20, 2012 1:10 am |
centxhunter
Agree, the jet takes a big engine to get similar performance. I think surface drive with rock guard will do it.
_________________ 1750 Gator Trax HD, MB 5000.
Sun Jan 22, 2012 10:37 am |
timebomb
Agree on the power for the jet. had a 25/20 mercury jet on a 14/48 Jon it was about worthless not near enough power plus try to start in somewhat shallow water intake will be clogged with gravel.
Mon Jan 23, 2012 9:13 pm |
PaleoHuntr
It was just a suggestion. They are very popular on the river up here on similar sized rigs, it's hard to find a regular outboard over 15hp and almost no MMs. Including mine there are 4 MM rigs and 2 airboats, most everything else uses a jet motor with a cover on the intake to prevent sucking up rocks.
Mon Jan 23, 2012 9:24 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 86 guests |
