It is currently Fri Jul 11, 2025 4:44 pm
Reply to topic  [ 6 posts ]
 Prodrive Hydraulic Trim??
Post Prodrive Hydraulic Trim??
I am changing the transmission oil in hydr trim and was wondering........after emptying the bowl and reassembling, should I have the motor all the way trimmed down or up before refilling?
Thanks for the input
Sat Sep 22, 2012 5:43 pm
Post Re: Prodrive Hydraulic Trim??
The reason I ask is when the hdryo lines blew 2 yrs ago and I had to replace them, I was told to make sure you have the motor all the way trimmed down(i think) before you fill with trans oil.
If I am just changing the oil from the resorvoir, and there is still oil in the lines, do I need to worry about whether the moror is trimmed up or down, or does it even matter?
Sat Sep 22, 2012 8:07 pm
It should have been trimmed all the way up before you started draining. When the rod is fully retracted it has displaced the most amount of fluid.
Sat Sep 22, 2012 8:09 pm
got it...I didnt drain it yet so I will be able to trim it up before I start.
Sat Sep 22, 2012 8:30 pm
Remember not to crack any of the lines or or engine will slam down hard and fast.
Sat Sep 22, 2012 8:38 pm
I had the original lines made to 4k PSI............pretty strong stuff!!
I also have blocks and a seat cushion uner the skeg....just in case.
Sat Sep 22, 2012 9:00 pm
Users browsing this forum: No registered users and 108 guests
