It is currently Fri Feb 13, 2026 6:57 pm
Reply to topic  [ 17 posts ]
 Shallow water
Post Shallow water
I would like to know which motor can take off best in a sand bottom prorive or Gator Tail
Fri Jan 30, 2009 9:59 pm
Post Re: Shallow water
I don't think you can get the PD as low for a bite in a hard bottom without digging a hole because of the large skeg. But at the same time that large skeg provides more prop protection IMO and alot less prop hits on junk. Any way you cut it, if you gonna decide on a motor based on holeshot in sand you better be ready to replace your prop every few months cause sand will eat them up no matter the motor.
18x48 Charles Leonard / 36PD
Fri Jan 30, 2009 10:16 pm
I have hard, shallow sand bottom in my marsh, especially since Rita and Ike. The best I've seen getting up is the MB 35 Mini with it's 32 out drive. The longer reach seems to make a big difference in this type of bottom. But, as stated before, if you're gonna get up in this stuff instead of poling to more water, be ready to go thru some props!
Sat Jan 31, 2009 10:11 am
I don't care what you run, your better have a spare prop if you going through sand.
Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Sun Feb 01, 2009 2:25 pm
Sun Feb 01, 2009 4:29 pm
I average 1 per split.
Sun Feb 01, 2009 4:31 pm
Sun Feb 01, 2009 11:25 pm
That is why some of us love the ole longtail...
Only lost 1/4" of prop all season long - and tossed my share of oyster shells and sand too...
Eat - Sleep - Hunt ! ! !
Mon Feb 02, 2009 7:08 am
Thanks for the replies I realize that sand destroys props I am running a tunnel boat right now and go through one a season. But in the area I hunt hole shot means alot because usually if you cant get on step you cannot go in reverse.
Mon Feb 02, 2009 6:48 pm
what kind of boat?
24x60 Dual Prodrives
Mon Feb 02, 2009 7:06 pm
1754 homemade aluminum hull with a 90 etec and hydraulic jackplate
Mon Feb 02, 2009 7:08 pm
Prop makes all the difference when trying to get up on a hard shallow bottom. Took me 4 props to finally get one that will get the boat up in a little over ankle deep with out submerging the prop. A 3 or 4 blade would work even better. Trying to get me a 4 blade built now. If you notice, the outboards on tunnel boats that shoot up on plane in the shallows use 4 blades with power to turn them quick and blow themselves out of the hole. I have done this with a two blade and am still tweaking on the three to do the same.
Mon Feb 02, 2009 9:16 pm
Tue Feb 03, 2009 8:46 am
He runs a Gatortail..I think he is a GT dealer.
Tue Feb 03, 2009 8:55 am
"Fight 'em until hell freezes over. Then fight 'em on the ice!"
Tue Feb 03, 2009 11:15 am
Tue Feb 03, 2009 11:40 am
I run a PD in a lot of sand and don't have much of a problem with it, but the guys I know who have run both seem to prefer the GT.
EVT Stage 1 32PD on a 17x48PD
"I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me."
Mike Huckabee
Tue Feb 03, 2009 11:43 am
