It is currently Wed Jul 09, 2025 10:20 pm
[ 9 posts ] |
Pro drive help, strange noise
Alex6528
Joined: Wed Nov 28, 2012 8:54 pm Posts: 142 Location: Katy, tx
Just noticed my pd making a very concerning noise when I engage the clutch, seems to go away when I rev up. I can't seem to post the video I took, if you pm me your number I can send it too you. Or just text me and I'll send it, I don't mind posting my number. 7135044621
Fri Jun 14, 2013 5:52 pm |
cb5331
 Re: Pro drive help, strange noise
The gears have a little lash in them and they do make a little racket at idle. You sure it's something new?
Is it coming from the LU or the clutch area?
Fri Jun 14, 2013 5:53 pm |
Alex6528
Just below the clutch. Above the lower unit. The shaft area, not sure if its new or not, ive never noticed it.
Fri Jun 14, 2013 6:15 pm |
Alex6528
I took a good video of it on my phone, I just can't get it to upload, is there someone that knows how to upload them I could text it too.
Fri Jun 14, 2013 6:24 pm |
cb5331
Only thing in that area is the spline adapter. I guess the allen head screws that hold it on could be loose? Or maybe you stripped it somehow?
If you are certain that it is below the clutch and above the knuckle, I'd lift it off as soon as possible and have a look...
Fri Jun 14, 2013 6:25 pm |
cb5331
It will probably be really hard to tell where the noise is coming from in a video. We're gonna have to take your word on it.
cb5331
I got your video, but it's hard to tell where it's coming from. There is an upper bearing in the top of the LU. I wouldn't think that would be it, but it's possible. Only other thing in between the gears and the clutch is the spline adapter. I can't think of anything else man.
You got an engine hoist? I'd lift the powerhead off and try to isolate it.
Fri Jun 14, 2013 6:49 pm |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
I had a noise start in mine, sort of a high pitched sound when I engaged the clutch. Ended up being the bearing in the LU just above the gears. Only way to be sure is to pull it apart. There's a seal just above the gears that'll sometimes leak a little water, which is the cause of the problem.
_________________ 35 GTR - 1754 Extreme
Fri Jun 14, 2013 6:53 pm |
Alex6528
Well, interesting story, the previous owner(hysrilla gorilla) broke a few bolts that holds the lower unit on and had it repaired at h&w, so I would assume all that's new. I drained the lower unit oil, no metal, it was a little milky, but just barely, could have been from the cheap ass Teflon I used.
Fri Jun 14, 2013 7:14 pm |
[ 9 posts ] |
Users browsing this forum: No registered users and 66 guests |
