It is currently Sat Jun 28, 2025 1:30 pm
Reply to topic  [ 25 posts ]
 Empty boat trailer.
Post Empty boat trailer.
Got abt a 450 mile haul with an empty trailer tomorrow. The son of a bitch likes to bounce too.
I found some heavy scrap steel around the farm to strap to it and it seems to work but after a 10 mile drive the shit has come loose already.
I have a 15 foot boat I could stick on the trailer but I'm picking up a hull down there and don't know how compatible they would be to stack and if it might damage one hull on the way back.
Any thoughts? Should I just let it bounce? Part of the trip involves that piece of shit they call I-10...
Thu Jan 15, 2015 2:41 pm
Post Re: Empty boat trailer.
30 to 50 gallon plastic barrel with water in it.
Thu Jan 15, 2015 2:46 pm
Couple of fat chicks?
Thu Jan 15, 2015 2:48 pm
Lay the barrel on runners above the axle fill with water until it runs out put cap on and tie downs.
Thu Jan 15, 2015 3:03 pm
Thu Jan 15, 2015 3:17 pm
Thu Jan 15, 2015 3:18 pm
that's what I did when I run from Arkansas to LA at gator trax.
Thu Jan 15, 2015 3:30 pm
I can screw a board down to the bunks in front of and behind the barrel to keep it from sliding
Thu Jan 15, 2015 3:31 pm
Empty most of the water out when you get there and load it in the back of you truck.
Thu Jan 15, 2015 3:35 pm
Thu Jan 15, 2015 5:13 pm
Fill it full
Thu Jan 15, 2015 6:29 pm
Thu Jan 15, 2015 6:36 pm
Well this will work out good but the only barrel I could find has a little motor oil in it. I don't wana go dump used motor oil from Georgia on the ground in Louisiana.
Thu Jan 15, 2015 7:28 pm
Might just have to let this bitch bounce and hope she hold together
Thu Jan 15, 2015 7:29 pm
I have taken 8-10 cinder blocks and strapped them to an empty boat trailer. It helps but it'll still bounce some. Easier to tie down than a barrel. Put as many as you can on the bunks, should be fine. Stack them in the truck for the ride home.
-Custom pool noodle
-stage 4 water wings
Thu Jan 15, 2015 7:41 pm
roundup barrel
Thu Jan 15, 2015 8:57 pm
Thu Jan 15, 2015 9:15 pm
Thu Jan 15, 2015 9:19 pm
Go to a local carwash. They usually have 20-30 plastic barrels waiting to throw away. And they hold biodegradable chemicals.
Thu Jan 15, 2015 11:40 pm
Fri Jan 16, 2015 8:35 am
Fri Jan 16, 2015 10:02 am
36 PD
1850 VooDoo custom by Dfou
Fri Jan 16, 2015 11:51 am
Fri Jan 16, 2015 10:53 pm
Quickrete tube sand.
MoMarsh Fatboy/2 Honda
Sat Jan 17, 2015 4:04 am
Update: didn't want to dump used motor oil in the ground. Wound up strapping the scrap metal on real tight. Made it from Atl To nola in tact. Now the boat is loaded and I'll be headed home tomorrow, decided to spend the weekend here. Thanks for the input guys. I know the water barrel would've worked had I had a clean one though.
Sat Jan 17, 2015 10:54 am
Users browsing this forum: No registered users and 310 guests
