It is currently Thu Jun 26, 2025 5:45 pm
Reply to topic  [ 29 posts ]
 Hunt deck
Post Hunt deck
Does anybody know someone that can build a custom hunt deck on to a boat around Southwest Arkansas?
Fri Dec 25, 2015 4:17 pm
Post Re: Hunt deck
You won't want to build it ONTO the boat you'll want to build it INTO the boat.
Fri Dec 25, 2015 4:43 pm
Post Re: Hunt deck
I know this and it needs to be braced well to hold the weight of a 35 sd
Fri Dec 25, 2015 8:22 pm
Post Re: Hunt deck
What boat are you adding this too?
Sat Dec 26, 2015 7:30 am
Post Re: Hunt deck
Weldbilt
Sat Dec 26, 2015 9:33 am
Post Re: Hunt deck
What gauge aluminum is it? If it ain't .125 Just sell it and buy what you want.
Sat Dec 26, 2015 5:53 pm
Post Re: Hunt deck
Weldbilt only goes up to .100 I'm pretty sure. Could be wrong
Sat Dec 26, 2015 6:40 pm
Post Re: Hunt deck
Sat Dec 26, 2015 7:27 pm
Post Re: Hunt deck
Sat Dec 26, 2015 8:20 pm
Post Re: Hunt deck
If you beef up the transom the boat will be fine. If your just using it for a marsh rig to get to a blind it will do ok , not great but ok. The hull will get hooks but if your just looking to get to a blind or shallow area to fish and not beating the hell out of the rest of the boat it will do ok. It will get hooks though but will be fine if your not looking to set any speed records.
Sat Dec 26, 2015 8:27 pm
Post Re: Hunt deck
It's .100 thickness. I can't afford to sell it and get a $7000 mud boat. Besides if I have a hunt deck added it will still be cheaper than buying a mud hull. Also I like the way it handles, the smooth mud hulls slide too much to run the rivers or timber around here.
Sat Dec 26, 2015 11:49 pm
Post Re: Hunt deck
May I ask why your wanting a hunt deck ?
Sun Dec 27, 2015 12:08 am
Post Re: Hunt deck
The transom is sitting too low in the water
Sun Dec 27, 2015 1:05 am
Post Re: Hunt deck
Have you tried moving weight around in boat? I have a rivited Alumacraft 1648 .072 gauge rig I've run for 6 Yrs now. We moved rear seat forward 16" and built in a 12 gallon tank in bow and reinforced transom. Theres no hooks in hull and it will run mid thirties. Have modded MB BD 4500 2013 motor on it. Running a Hammer Prop. Heres a couple pictures.
Sun Dec 27, 2015 8:19 am
Post Re: Hunt deck
We the thing I'd I can't move the battery or gas tank with cutting holes in the walls or front deck. I found out it will run 700 to add a hunt deck. The same guy can take my drop deck and make a door, then he can make an aluminum fuel cell to go under the deck which move weight up front. And Denny I've had trouble with front end being too light so I added sand bags in the front and I'm going to take it out this afternoon to see how it runs.
Sun Dec 27, 2015 10:06 am
Post Re: Hunt deck
Sounds like a fantastic setup. You should definitely keep dumping money into it.
Sun Dec 27, 2015 1:10 pm
Post Re: Hunt deck
:lol:
1854 Prodigy DPE Level 3 HDR
Sun Dec 27, 2015 1:15 pm
Post Re: Hunt deck
Why not stick with what you have till you can afford a better hull. Wasting your money on that boat. Lol like putting 3k worth of speakers and rims on a piece of shit car . Niggering it up !
Sun Dec 27, 2015 1:38 pm
Post Re: Hunt deck
Sun Dec 27, 2015 5:15 pm
Post Re: Hunt deck
I cut open my front deck and put a 12 gallon tank under it
Sun Dec 27, 2015 5:16 pm
Post Re: Hunt deck
Hey this hull is way better than what I had. It's also what I could afford.
Sun Dec 27, 2015 7:19 pm
Post Re: Hunt deck
Sun Dec 27, 2015 7:32 pm
Post Re: Hunt deck
The sand bags made a huge difference on the way it squats. I still would like to move my fuel tank up front to help move weight around tho
Sun Dec 27, 2015 9:11 pm
Post Re: Hunt deck
A hunt deck ain't gona change the way it squats. The boat will be the same length if its built in to the boat. Or longer if it's built off the back but the motor is still hanging off the back. Pods would lift the back bc they put floatation behind the weight of the motor.
Mon Dec 28, 2015 10:04 am
Post Re: Hunt deck
Building a huntdeck into a hull is going to take some time and some coin to do it the right way. I would hold off for now, change your load plan up so you have more weight to the bow, save some money and get a hulll with hunt deck.
Gator Trax 1750HD powered by a Mud Buddy 5500 BAMF
-Unbaffled VooDoo
-Gator Glide G2 with base
-Wet Sounds Stealth 10 Ultra V2
-Green LED Courtesy Lights
-15" Combo LED Light Bar
Mon Dec 28, 2015 10:37 am
Post Re: Hunt deck
It is a hull, not a haul.
Mon Dec 28, 2015 12:16 pm
Post Re: Hunt deck
Mon Dec 28, 2015 12:20 pm
Post Re: Hunt deck
-Unbaffled VooDoo
Mon Dec 28, 2015 12:29 pm
Post Re: Hunt deck
I'm gonna end up moving my gas tank up front and possibly my battery. My wife took pictures of it in the water with me in it yesterday and I like the way it is right now
Mon Dec 28, 2015 2:10 pm
Users browsing this forum: No registered users and 283 guests
