It is currently Wed Jun 25, 2025 11:11 am
Reply to topic  [ 2 posts ]
 Rio Grande 1232 Border Runner SPS 6.5hp Longtail build
New Member
Post Rio Grande 1232 Border Runner SPS 6.5hp Longtail build
Being my first post I figure this is a good a place as any. I just want to share my build to help others with ideas and and to get feedback to maybe improve my boat.
I got around to wanting to building a boat for running around on my little Rio Grande River and small Balmorhea Lake for running jugs, bowfishing, and duck hunting I do out here in the far West Texas Chihuahuan Desert.
The river is small and mostly rocky. It has sections that are deep enough for most boats but between these sections are many rocky rapids that not even a canoe could go through without having to get out and drag. So when I started to think about getting a boat to recreate on the hundreds of miles of river we have out here, I had to think about what would work. We have a 1450"ish" allweld boat with a 35hp jet motor the department got us to work the river but really it is too big and heavy unless the river is at dangerous flood levels. Jets are ideal due to the shallow hard rocky bottom but can be heavy and underpowered plus very expensive. Trying to build a boat on a budget, jets weren't an option. Standard prop motors weren't either unless you like to break props and lower units! That when I came across these Longtail motors. While they have a prop, a cheap one at that, the ability to bump over rocks was a very desireable feature.
I made calls to several companies that had decent looking kits. A couple got back with me, and we talked a bunch about what would work for me on a 12' aluminum Jon boat that I had decided was in my price range and would be light enough to run the river. Jon at SPS got my business. He was very personable, not that the other guy wasn't. The thing is that Jon has been in the Longtail business a lot longer than the competition. Also we both work in the same occupation, so not only do we have something in common, but I can pretty well assume he is a man of integrity and not going to screw me with a bad product. I will say he offered me a very generous discount, which I accepted, but I have tested this motor kit it some rough stuff before offering praise of his product.
So I received the kit. Boxed well and professionally. I ordered a cheap Harbor Freight Predator 6.5hp engine. $100 is hard to beat, blow it up and just buy another, no big deal. I assembled the kit and it is so easy a little girl can do it. I finally got over to an Academy Outdoors Store in El Paso that had the 1232 Alumacraft Jon Boat I'd been eyeballing and picked it up for $579. The Jon weighs 120lbs, and is light and small enough to be slid in a truck bed. I would recommend using a bed extender with the motor attached as it is 80 something pounds. So now I had a 200 pound skinny boat that could carry a couple good sized fellas and and some gear. Also it can be launched a lot of places anyone launching a trailered boat would be very troublesome if not impossible.
Now to testing this rig. I decided to go to this frog pond lake called Balmorhea where things were safer; not so remote, rugged, and less chase of running into a drunk Mexican. I put it on the lake and motored around. The thing would scoot pretty good! With my GPS, me, and a pretty much empty boat I got up to 15.4mph. I was running around with the 6.5" prop without the prop guard. I've stuck with the 6.5" after testing out different props 6", 6.25", and 7" with a prop guard. I chewed up a 6.5" prop pretty good at the river once I decided the rig wasn't going to leave me stranded miles from the truck with Mexico on one side. Surprisingly I hit a lot of rocks and the aluminum prop held up better than expected and it felt like I didn't lose much propulsion. Of course being a tinkerer and a little bit of HP junkie, I added a mud motor hop up kit from OMB Warehouse. It came with a opened up straight back header and muffler, a K&N style air filter, and a bigger carb jet to suit. It opened up the 6.5 pretty good, which I've read is terribly restricted stock. I also added a "hotter" racing spark plug, if anything it made it easier start which wasn't too hard in the first place.
A note about the prop guard. When I first tested it, with any prop size, I was having to lift very hard on the tiller handle to try to keep the prop at the ideal trim. After examining the reason why that was happening, I noticed that at the angle the shaft needed to be at there was a lot of flat metal acting as a trim tab in the un-needed direction. A crescent wrench and raw muscle fixed that by angling the two side supports downward at approximately 45 degrees. They are almost perfect, only under full throttle do I need to pull up slightly on the tiller handle to get my ideal trim. Not nearly the wrestling match I first experienced. I have not GPS'd the top speed since then, it seems to have the speed and prop protection I desire. I may tinker with it more if I get bored.
After several river trips and inspection of the hull, I noticed that the rocks were awfully hard on the boat. The bottom had a lot of dents and missing paint. Also, upon contact with a rock, the boat liked to stick pretty good. I began the search for a bottom coating. I settled upon a company called Wetlander. Scott seemed to be pretty straight with me, was honest about his product, and didn't try to push it on me. It was a little expensive, maybe $200 for a 2L kit which left a little left over for touch ups. I applied it with a paint roller, I tried with my cheap spray gun but I was having issues with the compressor and the gun didn't want to spray it well. Having a good bit mixed up, a water based silicon epoxy, I hurried and rolled it on before it set up. End result wasn't as smooth but it was definitely harder and slicker than painted aluminum. I'd recommend if you go roll on to smooth up the final coat with a paintbrush. The roller gave it an almost rhino lined texture, versus the brushed keels which were nice and slick when dry. After a couple outings the coating has held up well. It is scratched but not flaking off. The boat seems to not get stuck on rocks or gravel bars as bad. Though when it get rough or shallow enough, you just have to get out and pull it.
Other things I've added are a extended aluminum seat mount that allows for full range of motion of the tiller handle. It also puts my weight more center in the boat and I "plane" out better with only me in the boat. If you call 10-15mph planed out. I added an ATV double gun rack to the front bench. It actually holds an M4 and two shotguns nicely and securely. I installed some cleats, oar holders, and ropes for tying up. I carry a milk crate for random things in the back, along with a tool box with just about every tool to keep the motor running while out and about.
That's just about all I can think to say on my boat. It's a pretty neat toy to play around with I think. The SPS kit has been effective, reliable, and affordable. If there are any questions, suggestions, or comments feel free to reply. Here is YouTube video from duck hunting this morning, fetching a couple ducks my 12 year old son got a double on. Thanks for reading!
[youtube]http://youtu.be/_GWSXfiF61k[/youtube]
Sat Jan 02, 2016 9:46 pm
New Member
Post Re: Rio Grande 1232 Border Runner SPS 6.5hp Longtail build
http://youtu.be/_GWSXfiF61k Maybe the link works better this way, not sure with this forum.
Sat Jan 02, 2016 11:48 pm
Users browsing this forum: No registered users and 238 guests
