It is currently Mon Jun 23, 2025 12:12 pm
Reply to topic  [ 17 posts ]
 RPM Help
Post RPM Help
I have a 35 MD HD Stage 2. New prop pitch (1.5") added by Baggy's. I am hitting the rev limiter at 5200 RPM's. I think the gears are stock. Should I have the prop worked more or change gears? Hull is a 19 x 48 Mad Man square chine. I am running 33-34 at 5000+ rpm's. I have a 5200 max rev limiter.
Sat Jun 11, 2016 10:52 am
Post Re: RPM Help
Change gears
Sat Jun 11, 2016 10:57 am
Post Re: RPM Help
Any idea what tooth stock is?
Sat Jun 11, 2016 11:43 am
Post Re: RPM Help
38 and 50, I think. Deadbird would probably know for sure.
Sat Jun 11, 2016 11:57 am
Post Re: RPM Help
If it started as a 35 then 38 50 gears are stock
Sat Jun 11, 2016 12:28 pm
Post Re: RPM Help
Got some shit going on at Catahoula huh Russ?
Post Re: RPM Help
Recommendation on what I should go to?
Sat Jun 11, 2016 1:15 pm
Post Re: RPM Help
47, maybe. There was a chart on the mb site before they changed it. May still be able to find it on there or the bps site.
Sat Jun 11, 2016 1:56 pm
Post Re: RPM Help
Gary has probably answered that question upwards of 20 times on this forum..
Sat Jun 11, 2016 2:02 pm
Post Re: RPM Help
Mag 45. 38/48. Ive put 38/46 on a hot motor a year ago. But really your math/rpm seems high. How bout trimming down abit?
Sat Jun 11, 2016 2:03 pm
Post Re: RPM Help
When trimmed down, prop is not half out of water.
Sat Jun 11, 2016 2:28 pm
Post Re: RPM Help
This is in deep water as well.
Sat Jun 11, 2016 2:29 pm
Post Re: RPM Help
Going to a 46 lower will drop roughly 400 rpm. You should judge your trimming up by at wich point you stop gainning mph. After that just rpms rise but its loosing bite.
Sat Jun 11, 2016 2:39 pm
Post Re: RPM Help
That would be about 4600-4700
Sat Jun 11, 2016 3:42 pm
Post Re: RPM Help
Mine was a 35HD non CDI and it was 36/47
17/54 gator Trax 35 mudbuddy... mostly stock
Sat Jun 11, 2016 5:54 pm
Post Re: RPM Help
Sat Jun 11, 2016 8:16 pm
Post Re: RPM Help
Sat Jun 11, 2016 8:17 pm
Users browsing this forum: No registered users and 426 guests
