sskparker
 gt replacement trim
Got the new gt replacement trim. Installed it works great. But when trim is going down it makes a squealing noise. I backed all bolts off a little to make sure they where not to tight and it still dose it. Any ideas? Thanks
Fri Mar 01, 2013 7:18 pm |
garrettpearce
Joined: Mon Jul 27, 2009 8:10 pm Posts: 1436 Location: down da bayou
 Re: gt replacement trim
It's too g to clear up
Fri Mar 01, 2013 7:23 pm |
sskparker
it's too g to clear up?.........did u mean it will clear up?
Fri Mar 01, 2013 7:29 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Fri Mar 01, 2013 7:40 pm |
Gameover
Joined: Tue Jan 03, 2012 9:06 am Posts: 3673 Location: Prarieville,LA
I have the 2013 trim and it noisy but still works
_________________ 1754 GTR Xtreme CC w/ Purple Kool-aid Additives
Fri Mar 01, 2013 7:46 pm |
Gameover
Been like that since day 1
sskparker
thanks, will call gt monday just so they will know. i'll run it till then trim has a one year warranty. other than noise it seems to respond better than the old style trim.
Fri Mar 01, 2013 7:54 pm |
Wildberry
Joined: Sun Apr 22, 2012 6:17 pm Posts: 1018 Location: DA HAVEN FL,
Is the amount of trim the same on the new and old trim units ? Not that it matters was just qurious
_________________ EMF 16x42, 3/16 skiff, 35 GTR Stage 0
Fri Mar 01, 2013 8:03 pm |
sskparker
yes it is i marked it and trims just as much. when ordering they ask if u got 23 or 35hp. the differents is the piovit block that mounts on front side of trim.
Fri Mar 01, 2013 8:08 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
Some squeal on way down. Just keep working it & it'll stop eventually. It's just a lil air pocket causing the squeal and will work itself out.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Fri Mar 01, 2013 8:10 pm |
sskparker
thanks for all the posts. i will run it a bit. and then give a update. i thought that, that it was air in it.
Fri Mar 01, 2013 8:18 pm |
Team Camo
 I might've had 1 or 2 or 3 or...
Fri Mar 01, 2013 8:28 pm |
garrettpearce
Yes auto type. It should clear up. Mine did when I had it
Fri Mar 01, 2013 8:36 pm |
FowlMouth251
Joined: Thu Apr 26, 2012 7:27 pm Posts: 644 Location: mobile al
Just bought one a couple months ago and it did it at first but cleared right up!
_________________ 1746 GTB 35 GTR
REFRIGERATOR STAY EMPTY CAUSE I EAT GOOD
Fri Mar 01, 2013 8:44 pm |
gmccurry
Mine does the same.
Sat Mar 02, 2013 11:22 am |
theplayer
I know this is old but I got the new style GT trim unit 3-4 years ago and it squeals on trim down but not on trim up. I thought it would go away but it never did. It still squeals on trim down if it has been sitting on trim up for a while with the motor level. If I let it sit trimmed down for a while it won't squeal at all. It has to have air in the fluid. Do others still have units that squeal on trim down? Anybody know a fix like adding fluid or trying to bleed out air?
Sun Mar 04, 2018 7:56 am |
