It is currently Fri Feb 13, 2026 10:56 pm
[ 4 posts ] |
mudpack
 Vibration in longtail
I have a Mudbuddy 13hp (Honda GX390 with reduction gearing). I bought it used nine years ago and it has been a great unit with one exception: it has a harmonic vibration at full throttle...had it from day one. It's a "thrum-thrum-thrum-thrum" vibration that reverberates throughout the hull. I originally thought it was the result of having only one universal joint in the drivetrain, so i replaced the U-joint with a constant-velocity joint (CVJ). This was five years ago and the harmonic vibration remains. Nothing seems to be coming apart. The prop looks new and the driveshaft shows no signs of being bent, but I have not removed it to put a dial indicator on it. Any suggestions? I hate the thought of buying a new unit just to cure a vibration.
| Mon Dec 16, 2019 9:59 am |
Will C
 Re: Vibration in longtail
Remove the prop and rev it up. This could help isolate the issue. Also im not up to date on the 13hp. Is it a single or a twin?
| Mon Dec 16, 2019 10:45 am |
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
Is it just shaft whip? Is it fully greased? The 13hp Honda is a single. I had a small MB longtail that did the same thing.
| Mon Dec 16, 2019 5:49 pm |
Will
Sounds like the shaft to me.
Sent from my Pixel 2 using Tapatalk
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Mon Dec 16, 2019 8:12 pm |
[ 4 posts ] |
