It is currently Sun Jun 09, 2024 12:17 pm
[ 6 posts ] |
Hunterk
MB 35HD problem
I haven't been able to get an answer from anyone but I'm sure I'm not the only person this has happened to. So I bought a 2009Hd 35 HP from a friend. I ran the motor a couple months before and ran wide open no problems. It sat for a month before I bought it. Now won't get on plane. At first thought it was a prop issue so I put on a new prop and nothing. So then I was convinced the clutch was slipping and bought a brand new clutch and everything and still won't work. At idle or lower rpms it works and you can feel the motor pushing but when you're starting to speed up it feels like when you spin a prop on a regular outboard. And you can feel it grab on and then spin and grab on and spin again. Not sure the rpms. But I need to get this thing going. Changed spark plugs and fuel filter it's on the same boat I ran it on. Please help.
Mon Dec 23, 2019 7:47 am |
Mallards Only
Joined: Wed Jan 14, 2009 9:23 pm Posts: 404 Location: Idaho
Re: MB 35HD problem
I guess the first most obvious question is did you just buy the motor and put it on a different hull or did you buy the whole rig from him?
_________________ 1860 Prodigy
Wed Dec 25, 2019 7:29 am |
GNSPEED
Re: MB 35HD problem
wire from clutch to battery direct both power and ground if it still slips its probably something with lower gear and taper lock.From what you are describing that's my best guess.
Wed Dec 25, 2019 10:38 am |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
Re: MB 35HD problem
sounds like you lost the taper lock on the lower unit gear
Sent from my SM-G973U using Tapatalk
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
Wed Dec 25, 2019 10:52 am |
bluesky2012
Re: MB 35HD problem
Wed Dec 25, 2019 8:56 pm |
DmaxHunter
Re: MB 35HD problem
nothing beats the cam lobe of a pivot shaft... and the method of extraction. to the op I found key stock at my local o Reilly's. 3/16 or 1/4 the gtr takes the 1/4
Wed Dec 25, 2019 9:33 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 154 guests |
