It is currently Fri Jan 30, 2026 11:53 am
Reply to topic  [ 53 posts ]  Go to page Previous  1, 2
 reverse
Post Re: reverse
Brooks PM at ya.
Tue Mar 24, 2009 3:46 pm
Post Re: reverse
Tue Mar 24, 2009 6:38 pm
Post Re: reverse
Here's the vid.
Wed Mar 25, 2009 7:03 pm
Post Re: reverse
Ok, I up my bid to $100. Tell me what I need to do to get one of these. I'm lazy and would use my reverse more often if I didn't have to reach back and pull the pin.
Thu Mar 26, 2009 12:27 am
Post Re: reverse
I rather that than the hydro reverse. Even if that thing breaks tou can still pull da pin manually.
Thu Mar 26, 2009 7:48 am
Post Re: reverse
Thu Mar 26, 2009 6:20 pm
Post Re: reverse
the one Preston gave me fits on my motor just fine... I just need to run a tap through a couple of holes and extend the threads all the way through.
24x60 Dual Prodrives
Fri Mar 27, 2009 7:31 am
Post Re: reverse
Fri Mar 27, 2009 8:17 am
Post Re: reverse
I got access to a free use of a cnc.
There is no replacement for displacement!!!!
Fri Mar 27, 2009 8:46 am
Post Re: reverse
Theres three holes that can be used to mount the remote reverse box to the reverse ring. Crews I'm not sure which hole the taps in but you can still use the other two. and instead of taping out the existing 5/16 holes, just remove the 5/16 bolts and use a couple 1/4" stainless bolts long enough to go all the way through with a set of lock nuts to hold it all together.
Fri Mar 27, 2009 10:01 am
Post Re: reverse
Fri Mar 27, 2009 11:37 am
Post Re: reverse
could she drill plate!
Fri Mar 27, 2009 11:39 am
Post Re: reverse
Fri Mar 27, 2009 12:04 pm
