tchauvin
Joined: Wed Jul 13, 2011 6:23 pm Posts: 4898 Location: Bourg LA
 Re: Pro Drive vs Gator Tail
Wed Sep 19, 2012 2:34 pm |
craig
Wed Sep 19, 2012 2:42 pm |
cb5331
Wed Sep 19, 2012 2:43 pm |
craig
Wed Sep 19, 2012 2:49 pm |
MaXXis85
The few CDI's i have been around I was not impressed. I like my standard briggs leaky crank case motor.
Wed Sep 19, 2012 2:55 pm |
craig
Wed Sep 19, 2012 3:00 pm |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
_________________ 35 GTR - 1754 Extreme
Wed Sep 19, 2012 3:05 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
I run a pd and I love it. My next one will be a gtr simply because I have never owned one and I like them. If I run it for a year or so and still prefer the pd, I will sell it and get another pd. It's hard to know ford is Better/worst if all you have ever owned is Chevy kind of thing.
_________________ You have your whole life to be an idiot, take a day off!
Wed Sep 19, 2012 4:13 pm |
PASBON
_________________ "The philosophy of gun control: Teenagers are roaring through town at 90MPH, where the speed limit is 25. Your solution is to lower the speed limit to 20." - Sam Cohen Remember, four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
Wed Sep 19, 2012 5:07 pm |
tchauvin
Wed Sep 19, 2012 5:24 pm |
cb5331
This is not an alternator. It does not kick on and off. When the motor is running, the charging system is working. It does not care about the load you put on the battery. It works as hard as its going to work either way.
Wed Sep 19, 2012 5:34 pm |
tchauvin
Wed Sep 19, 2012 5:37 pm |
Migrator
Joined: Sun Apr 17, 2011 2:29 pm Posts: 3227 Location: Black River, MS
_________________ WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Wed Sep 19, 2012 5:43 pm |
cb5331
Wed Sep 19, 2012 5:45 pm |
cb5331
Wed Sep 19, 2012 5:56 pm |
Team Camo
Anyone that would eat a possible state record triple tail without verifying first should not try to argue with a motorhead about horsepower.
tchauvin
Wed Sep 19, 2012 6:00 pm |
cb5331
Wed Sep 19, 2012 6:05 pm |
tchauvin
Wed Sep 19, 2012 6:12 pm |
cb5331
I'm not arguing how much of a difference it makes in speed. I came in when we started talking about charging systems.
Wed Sep 19, 2012 6:16 pm |
duckduckboom
Idle issue- shitty heads/valves Cdi- put out the same regardless of whether anything is attached. Running your car, no electronics running, then Turn everything on at once and you will hear the diffence. Run a cdi at idle and hook 10 sealed beams and you will NOT hear the difference. It is putting out the maximum it can put out all the time. The reason you don't hear the diffence because it is always putting out the same amps. there is no change meaning the strain you hear in your car, is always on the marine engine
Wed Sep 19, 2012 6:17 pm |
tchauvin
Wed Sep 19, 2012 6:18 pm |
duckduckboom
Speed is relevant to gear ratio and angle of thrust. The only reason that a vertical has 36 hp and a horizontal has 35 hp is because of the intake design. Vertical engines have a less restrictive fuel flow to combustion chamber making it therefore more efficient.
Wed Sep 19, 2012 6:20 pm |
deltaduckmaster
Back on topic T my Gtr on basically the same size boat as you will walk away from your pd from 550 rpm to 4250!! O it's a none Cdi !! Lol
cb5331
Wed Sep 19, 2012 6:22 pm |
duckduckboom
Coach is speed is that big of an issue get a gtr but I live in thibodaux and will give you my number for when you get stuck But seriously, test drive a gtr that instant reverse is nice and they walk the dog on a pd in the mud. My father always told me "if it ain't broke, don't fix it" my response " if it ain't broke, it can always run better"
Wed Sep 19, 2012 6:28 pm |
tchauvin
Wed Sep 19, 2012 6:31 pm |
tchauvin
Wed Sep 19, 2012 6:33 pm |
duckduckboom
A GTR IS FASTER THAN A PRODRIVE. end of story. Gear ratio + more parallel thrust= speed. Gtr has both over pd.
Wed Sep 19, 2012 6:35 pm |
deltaduckmaster
Wed Sep 19, 2012 6:39 pm |
tchauvin
Wed Sep 19, 2012 6:44 pm |
deltaduckmaster
Wed Sep 19, 2012 6:45 pm |
deltaduckmaster
you say you have mods on a 17x54 at 30 mph I think your boat is slow!! I ran faster than that stock !! Lol
Wed Sep 19, 2012 6:46 pm |
craig
Wed Sep 19, 2012 6:47 pm |
tchauvin
Wed Sep 19, 2012 6:49 pm |
craig
Wed Sep 19, 2012 6:50 pm |
tchauvin
Wed Sep 19, 2012 6:51 pm |
craig
That's it?
I catch 4ths.
Wed Sep 19, 2012 6:52 pm |
craig
Wed Sep 19, 2012 6:53 pm |
tchauvin
3 so far, I have done more on outboards than pd's....but I cannot seem to kill mines!
Wed Sep 19, 2012 7:03 pm |
