Oil/Grease below clutch???
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=1004
Author:  Full Throttle [ Sun Mar 08, 2009 6:22 pm ]
Post subject:  Oil/Grease below clutch???
I am getting a bunch of oil or grease build up below the clutch. Is this something to be worried with or is it normal? I thougth maybe I put too much grease in the grease jerks but this is kind of a milky color. I do have a case gasket leak that hasn't been fixed, but I don't think it is related to this as I am not loosing that much oil.
Suggestions?
Author:  JIMMY W [ Sun Mar 08, 2009 8:31 pm ]
Post subject:  Re: Oil/Grease below clutch???
Water is getting in lower unit!Mine did the same thing,Change the seals!
Author:  POKER1 [ Sun Mar 08, 2009 8:45 pm ]
Gear lube from the lower unit. Grease will not change color and mix with water like that. Probably need a new upper seal.
Author:  Full Throttle [ Mon Mar 09, 2009 5:52 am ]
What's involved with changing the seals???? Is it an easy job? The engine only has 60 hours on it. How much will the seals run?
