Tcounty
Joined: Wed Jan 14, 2009 4:45 pm Posts: 168 Location: West TN
 What do yall think about this??
_________________ 1648 old style bass tracker with a...........................
50 Nissian on a 17' Lakesport.
Thu Jul 22, 2010 1:54 pm |
instagator911
Joined: Sat Dec 05, 2009 12:36 pm Posts: 1127 Location: Behind the hood next 2 da bright light! SETX
 Re: What do yall think about this??
Realy?
JUNK!!!
_________________ Jay Dore
Thu Jul 22, 2010 4:07 pm |
dead duk
Joined: Thu Jun 25, 2009 10:45 am Posts: 147 Location: Longview,Texas
In my opinion, it does not work. You might be able to use it sparingly to fill small holes, but for "fabrication" work, it will not penetrate well enough compared to a weld. I experimented with the stuff a couple of years back to see if the applications were similar to welding and they are not. If you have fabrication work that needs to be done, take the boat to a professional and get it done right. Furthermore, if you are not careful with the rods, you run the risk of blowing a hole in the aluminum, due to aluminum's low melting point.
Thu Jul 22, 2010 4:14 pm |
cb5331
Thu Jul 22, 2010 4:30 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
_________________ 1850 & 36pd
Thu Jul 22, 2010 8:15 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
If you do it right, it works. Getting it hot enough and tinning it is the key, I did a crack in my boat where the bow is pulled together about 4 inches long, I made a patch a couple inches longer than the crack and about 3 inches wide with holes drilled in it for the braze to seep in. I've beached it a bunch of times since then (that's how the crack got there) and it hasn't budged. I brazed 2 pieces of aluminum together messing around, and I broke the aluminum trying to get the braze to break.
_________________ Put yer face in the myrtles.
Thu Jul 22, 2010 10:29 pm |
DeathMetalDukk
Get mapp gas if you can instead of propane also, works quicker and you can heat a larger area, gets a lot hotter.
Thu Jul 22, 2010 10:31 pm |
fishermann222
Joined: Sat Jul 10, 2010 9:09 pm Posts: 9 Location: Western Alaska
Any of you ever use Z-spar? Works quite well. Buddy hit a pole and punched a 3 inch hole in his boat, we zsparred it in the river, patched it, waited an hour, drove home. Was going to be a temp fix, however 4 years later it is still as good as new.
Fri Jul 23, 2010 12:01 am |
Tcounty
It works. I ordered it off of Ebay. A small kit with 10 rods ,dvd and 2 tinning brushes. Tryed it last night. Drilled a 1\4" hole in a piece of .63 sheet and filled it in no problem. I then but "welded" 2 pieces together making a tee, couldn't break it apart. Also lap jointed with same results. I know this won't take the place of tig, but it is a quick and easy fix for small leaks, which is what I bought it for. One thing I did find out which in my mind is a plus, if you don't like the way something turned out just heat it back up and take it apart. Good stuff IMO.
Wed Jul 28, 2010 7:05 am |
