It is currently Fri Jun 20, 2025 8:56 pm
[ 5 posts ] |
fishermann222
Joined: Sat Jul 10, 2010 9:09 pm Posts: 9 Location: Western Alaska
 Pro Drive experts?
Ok Second trip out was fantastic, that thing zips across areas with literally no water in them. AMAZING.
I got it stuck in a BAD way in a creek to narrow to turn the boat around and had to reverse in a hurry. I totally blew it and forgot the to put in the reverse block (manual tilt).
It kicked up alot and got me unstuck, but my question is is it possible that I did damage to the tilt mechanism? It appears to be working ok, but when I got unstuck the trim wheel looked like this. Notice the nut so far from the wheel.
I didn't notice it until i got home, and then I moved the nut back down to the trim wheel and worked the wheel back to the bar so it looks like this now.
Did I mess something up? or did the bolt just work its way loose? Thanks in advance for helping this idiot out.
Thu Jul 22, 2010 7:05 pm |
quackconsumer
 Re: Pro Drive experts?
I'm not a PD owner but from da looks of things I would say roll wit it.
Thu Jul 22, 2010 7:20 pm |
tchredneck
Joined: Tue Jan 13, 2009 7:39 pm Posts: 1812 Location: in the woods,la
lol dont worry roll with it
_________________ 27 Contender twin 200's for sale 18x42 B.B skiff Lil daddy 36 pd Fighting da Koolaid brigade since 07'
Thu Jul 22, 2010 7:55 pm |
fishermann222
My other question is would that fuel filter you see in the photo hamper the fuel flow to the motor? On the way out motor ran great, on the way back, it would loose RPM's once in a while, and if i pumped the ball it would go back up to normal. I have heard some guys put an electric fuel pump in the line if you go through a filter, what do you all think?
Thu Jul 22, 2010 9:41 pm |
bluebill
Dont have a manual trim, but it looks like your fine on question 1.
Regarding your second question, you've got air getting into your fuel line. I've had the same problem with my PDs. Make sure you have hose clamps on all your fuel line connections. If that don't fix it, just run direct from your fuel filter to your tank.
Fri Jul 23, 2010 2:14 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 141 guests |
