It is currently Fri Jun 20, 2025 9:30 pm
Reply to topic  [ 10 posts ]
 Mudbuddy Problems
Post Mudbuddy Problems
I got a 29 horse mb with a kohler enginge. well i went rididng yesterday and my boat was running fine then the prop just stopped turning. the motor didnt cut off but the prop wouldnt spin. this is my first mud motor and ive never had any problems with it. im thinking the belt just came off but any ideas you guys have would be fantastic cause i really dont know. its not making any funny sounds just the prop wont spin.
Mon Jul 26, 2010 10:52 am
Post Re: Mudbuddy Problems
Does it have a clutch? Does it engage? If not take the housing off and see if your belt is broken. What frame do you have?
Mon Jul 26, 2010 10:54 am
It's been a while since I've tinkered with a MB but it takes 5-10 minutes to pull the belt housing cover off. Pull it off and check out the belt.
Pro Drive m'fers
Mon Jul 26, 2010 11:00 am
to be completly honest i dont know if it has a clutch but i am gonna pull it off the belt housing and look at it this evening maybe i can figure it all out
Mon Jul 26, 2010 3:08 pm
Does it have neutral? lol
Mon Jul 26, 2010 3:11 pm
oh dang that was stupid of me no it does not have neutral which means no clutch i took the belt housing off and the belt is tore up. there was also a little bit of water in the bottom of the housing, is that normal? and how do you tighten the belt?
Mon Jul 26, 2010 6:26 pm
there should be a screw/plug at the bottom of da housin u can back out to drain da water, dats how my GT is, im not quite sure how to tighten da belt, im sure someone else can help u wit dat.
Mon Jul 26, 2010 7:13 pm
call mudbuddy and get a new belt and they will tell you what all you will need to do it.
Mon Jul 26, 2010 8:50 pm
ga sent you a pm with some info.
1850 & 36pd
Mon Jul 26, 2010 10:30 pm
thanks for all your help guys i got the new belt ordered and hope to be back on the water soon
Tue Jul 27, 2010 9:09 am
Users browsing this forum: Google [Bot] and 128 guests
