| Tool Box http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=11326 |
| Author: | dozrya [ Mon Aug 02, 2010 1:08 pm ] |
| Post subject: | Tool Box |
Just looking through my tool box that is in my boat and was wondering what you guys carry. I have screwdrivers, pliars, wire cutters, etc, along with all my wire connectors. Anything else you guys have on board? Thanks, RyanD |
| Author: | cb5331 [ Mon Aug 02, 2010 1:11 pm ] |
| Post subject: | Re: Tool Box |
socket set, hammer, open end wrenches, electric or duct tape, spare fuses |
| Author: | Shadow [ Mon Aug 02, 2010 1:41 pm ] |
It doesn't matter I could carry every tool I have and you'll still never have the one you need. spark plugs |
| Author: | WestEndAngler [ Mon Aug 02, 2010 1:44 pm ] |
Off. Sun Tan Lotion, First Aid kit, spare prop, socket set, screwdrivers, open ended wrenches, spot lights, electrical tape, duct tape, life jackets, fire extinguisher and Toilet Paper |
| Author: | JBREAUX [ Mon Aug 02, 2010 1:47 pm ] |
Condoms, cause you never know. |
| Author: | Robn1020 [ Mon Aug 02, 2010 1:54 pm ] |
I now carry a "PHUCKITALL". It's a primo Cigar and weatherproof lighter in a case. Sandbars are da devil! |
| Author: | Shadow [ Mon Aug 02, 2010 1:56 pm ] |
Seems from what I have read you might want to carry a spare key! |
| Author: | quackconsumer [ Mon Aug 02, 2010 2:06 pm ] |
Toilet Paper |
| Author: | WestEndAngler [ Mon Aug 02, 2010 2:09 pm ] |
I do carry windproof lighter & 5 oz of whiskey & a 3 cigs in my ditch bag lol I do have a spare key on me at all times... I've broken one accidently when on a run. |
| Author: | UNCLE-J [ Mon Aug 02, 2010 2:12 pm ] |
Socket Set Screw Driver Set Allen Wrench Set Jumper Cables Off Bug Spray Extra GPS (incase someone stills your original) Extra Key (incase Someon hides your original) Spare Clutch Spare Prop Spare Prop Nut Hardware Single Man Tent Bottle of Pain Pills Bandaides Homemade Wine Steriods and proper needle (incase you are stuck and dont have the right amount of strenth) Candy (to keep Craigs Son accupied) Electrical Tape Lighter Shackles Fish Shocker Spark Plugs Spark Plug Socket Flare Kit Spare Pair of Underwear |
| Author: | WestEndAngler [ Mon Aug 02, 2010 2:16 pm ] |
Jason you forgot the TP |
| Author: | dozrya [ Mon Aug 02, 2010 2:50 pm ] |
HAHA....Like I said, I have the basic tools and all the required boating equipment. Just checking to see if there was anything on the engine that I should carry extra of. |
| Author: | WestEndAngler [ Mon Aug 02, 2010 2:55 pm ] |
I do carry extra oil & brake fluid on the boat |
| Author: | Shadow [ Mon Aug 02, 2010 2:58 pm ] |
| Author: | WestEndAngler [ Mon Aug 02, 2010 3:01 pm ] |
| Author: | DeathMetalDukk [ Mon Aug 02, 2010 3:39 pm ] |
| Author: | deadbird8 [ Wed Aug 04, 2010 5:39 am ] |
Motor is metric- for the stuff you will do on the water a 8, 10, 12, 13 mm wrench (17mm for a mikuni fuel bowl), flat (large and small), phillips and T30 Torx screwdrivers, needle nose and regular pliers, small crescent wrench, metric allen wrenches, plug wrench and spare plug/s, prop wrench or socket, elec tape, spare fuses (if you have them), a long length of wire and wiring diagram (allows you to bypass or reverse failed switches if needed), spare fuel filter, a small spool of twine, and a knife. I also carry a spare prop and a primer bulb with a length of line and hose clamps (I don't run with a primer bulb but have one in the box if required). Spare lighter, some fire starter, a small folding saw. |
| Author: | UNCLE-J [ Wed Aug 04, 2010 8:12 am ] |
| Author: | WestEndAngler [ Wed Aug 04, 2010 9:27 am ] |
| Author: | TDUET [ Mon Sep 13, 2010 7:11 pm ] |
| Author: | POKER1 [ Mon Sep 13, 2010 7:31 pm ] |
| Author: | DeathMetalDukk [ Mon Sep 13, 2010 9:57 pm ] |
