It is currently Fri Feb 13, 2026 6:50 pm
Reply to topic  [ 22 posts ]
 Boat Trailers
Post Boat Trailers
Having a hard time finding a reasonably priced, quality trailer.
Other than McClain and Magic Tilt, what else is out there??????
WC Custom 1854
Thu Mar 19, 2009 6:53 am
Post Re: Boat Trailers
Sportsman
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Thu Mar 19, 2009 6:54 am
I have never been impressed with Magic Tilt but I saw a Gator Trail, manufactured by them (I think) that looked pretty good. Set up for a mud boat with plastic boards and this one had wide tires.
17' CAT 5 with 37 GTR
Thu Mar 19, 2009 8:20 am
I bought a sportsman galvanized trailer from Black's Marine in Lafayette, and I'm happy with it so far. Priced about the same as a McClain, but it seems to have a longer box section than the McClain's I've seen. Pulls great. I had them add LED lights. The only problems I've seen with it is the wiring is not enclosed (it's a C-channel trailer) and they put Carlisle tires on it.
1848 Brother w/ 36 PD
Thu Mar 19, 2009 8:55 am
Thu Mar 19, 2009 9:41 am
All galvanized are priced in the same range. If you got the dollas and wanting a new one go aluminum and be done. Pro Drive got em, and I'm sure many others do. My boat came with one, it's a backtrack by Xpress.
It Was Won!!!
Enjoy It!!!
Thu Mar 19, 2009 10:00 am
I got a Dixie Craft trailer with my rig and I have to say it's an impressive trailer. Well built.
1660 Rhino High-Side with center console
90/65 Mercury 2 stroke Outboard jet pump
Run shallow, run loud.
Thu Mar 19, 2009 10:22 am
What are you wanting galvanized, powder coat, painted?
What size?
How quick do you need one?
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Thu Mar 19, 2009 11:10 am
Diamond City
Crisis defines character
Thu Mar 19, 2009 12:13 pm
WC Custom 1854
Thu Mar 19, 2009 4:15 pm
Get one built by Brother or Willy. You will be happier in the long run.
Thu Mar 19, 2009 5:18 pm
Thu Mar 19, 2009 8:48 pm
I only know of a couple of places that might can galvanize one but know of several places that can powder coat one and it'll make it alot lighter especially liftin up off the truck and such
I can weld aluminum but dont have a shop or machine right now that can weld aluminum but can build you a steel one.
Mostly need to know length of boat, length or trailer you want, and the beam of the boat and if it has much of a flare on the sides (brother puts a large flare in the front of his skiffs, dunno bout his bateaus)
Otherwise brother can build you a damn nice trailer to go with a damn nice boat.
Pete Willett
Thu Mar 19, 2009 9:49 pm
There is a place in Houston that Galvanizes. We use a place here in Baton Rouge at work, but getting it done isnt too cheap.
Fri Mar 20, 2009 7:29 am
yea I know of a place about an hour from me in Waskom that does galvanizing but im sure they arent cheap either thats why i was sayin better to go with powder coat or paint plus alot lighter weight
Pete Willett
Fri Mar 20, 2009 7:39 am
Galvanizing adds about 6% - 8% to the weight of a fabricated piece. Its been a few years but as I remember I charged $300 for a single axle and $350 for a double axle minimum at $.38 per pound. Might not be as expensive as you think.
Fri Mar 20, 2009 8:03 am
place here in Fort Worth called Aztec Galvanizing that will do it. They did my airboat trailer for $400, and it's not a small trailer.
I would stay away from powder coat. It doesn't hold up very well in my opinion.
"Fight 'em until hell freezes over. Then fight 'em on the ice!"
Fri Mar 20, 2009 8:59 am
SandyMans ~ Thats a dang good lookin' rig you gots there !!! :D
Now ~ When can I goes fo a ride ?!?!?
Fri Mar 20, 2009 9:37 am
OTL you are correct with your 6% ish weight increase. and most galvanizing shops charge you on the weight of the peice for pricing.
Fri Mar 20, 2009 9:41 am
Hmm not too bad may be lower or higher with the economy
Aztec is also in waskom and would use them if that's the route he or anyone wanted to take
The trailer I have is black powder coat and although its only bout 6 months old I haven't seen any problems out of it but only time will tell and is a lot lighter than my old McClain and has more material in it
Pete Willett
Fri Mar 20, 2009 5:55 pm
WC Custom 1854
Fri Mar 20, 2009 5:59 pm
