It is currently Fri Feb 13, 2026 6:49 pm
[ 2 posts ] |
Mallards Only
Joined: Wed Jan 14, 2009 9:23 pm Posts: 404 Location: Idaho
 PD Hydro trim
Gotta replace the reservoir tank because it's leaking. Sounds like others have had the same problem. Any tricks I should know before replacing it? How do I bleed/re-prime the lines?
_________________ 1860 Prodigy
| Thu Mar 19, 2009 7:38 am |
willett
Joined: Wed Jan 14, 2009 10:22 am Posts: 1764 Location: Tyler, TX
 Re: PD Hydro trim
do you currently have the clear plastic tank or the black metal tank?
When i did mine I trimmed the motor down, undid the lines (leak a little when off) undid the tank put new tank on, make sure fluid is full on dip stick then trim it up and down several times to get the air out and was good to go
_________________ Pete Willett WC Custom Boats - Tyler, TX http://www.wccustomboats.com
WC Custom 2048 3/16 Bottom Center Console with 35 PD EFI GTR WC Custom 1840 Hybrid 3/16 Bottom with 37 EFI BOSS
| Thu Mar 19, 2009 9:53 pm |
[ 2 posts ] |
