It is currently Sat Jun 08, 2024 7:22 pm
[ 5 posts ] |
JBREAUX
Joined: Tue Jan 13, 2009 8:12 pm Posts: 412 Location: soufff la
HELP!!
Gator-tail is closed today and my power trim broke today on my gator-tail and need it tomorow. my relay is clicking when i hit my switch that fuse like a 25amp i believe is still good i'm hoping the trim unit itsself isn't burnt up does anyone know what else i could check??
Sat Mar 21, 2009 5:23 pm |
TXSHOCKWAVE
Joined: Tue Jan 13, 2009 5:51 pm Posts: 295 Location: Karankawa Lake TX
Re: HELP!!
Hit the braker reset buton. Also if you run in salt water check every connection for corrosion. Next pull the relays and switch them around.
Sat Mar 21, 2009 6:00 pm |
JBREAUX
Re: HELP!!
thanks i ended up finding the problem it was the connector where the blue and green wires connect to the white and black, butt spliced them together for now and good to go.
Sat Mar 21, 2009 6:51 pm |
TXSHOCKWAVE
Re: HELP!!
cool
Sat Mar 21, 2009 8:21 pm |
etquackster
Joined: Tue Jan 13, 2009 8:47 pm Posts: 333 Location: tyler ,tx
Re: HELP!!
jb if that ever happens again ... put the blue wire on positive side of battery and that will make it go up if want it to go down put the green wire on positive....
_________________ boatless!!!!!!!!!
Sun Mar 22, 2009 12:04 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 184 guests |
