It is currently Fri Feb 20, 2026 9:54 am
Reply to topic  [ 6 posts ]
 AMP draw for handheld spotlight?
Post AMP draw for handheld spotlight?
How many amps will a 1 million candle light handheld spotlight draw on 12V plug? Looking at installing an electrical distribution switch panel with breakers and want to be sure my breaker is big enough. Thanks in advance.
Crisis defines character
Thu Sep 09, 2010 7:19 am
Post Re: AMP draw for handheld spotlight?
Divide the wattage of your device by the voltage of your system to calculate the amperage draw. (Watts/voltage=amperage). For example: a 55 watt light would draw a little over 4.5 amps on a 12 volt circuit. (55/12=4.583)
“Believe none of what you hear and half of what you see.”- Benjamin Franklin
"Advertisements contain the only truths to be relied on in a newspaper." -Thomas Jefferson
Thu Sep 09, 2010 1:32 pm
this will help out with wire size that you need
http://www.powerstream.com/Wire_Size.htm
Fri Sep 10, 2010 10:52 am
Ok if you use Ohm's law (w=E/I) 1000000/12v=83333.00 amps!?
I would say 15 amps is good enough---look at it like this I have seen many people out coyote hunting running a 1000000 candle power spotlight with a 12v cigg. lighter it is usually fused at 15 amps.
Hope this helps
Fri Sep 10, 2010 2:57 pm
Fri Sep 10, 2010 8:29 pm
I am going to go with a switch panel with (6) 10amp circuits.
Fri Sep 10, 2010 10:20 pm
