AMP draw for handheld spotlight?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=12256
Author:  duckhunter888 [ Thu Sep 09, 2010 7:19 am ]
Post subject:  AMP draw for handheld spotlight?
How many amps will a 1 million candle light handheld spotlight draw on 12V plug? Looking at installing an electrical distribution switch panel with breakers and want to be sure my breaker is big enough. Thanks in advance.
Author:  SMartin [ Thu Sep 09, 2010 1:32 pm ]
Post subject:  Re: AMP draw for handheld spotlight?
Divide the wattage of your device by the voltage of your system to calculate the amperage draw. (Watts/voltage=amperage). For example: a 55 watt light would draw a little over 4.5 amps on a 12 volt circuit. (55/12=4.583)
Author:  keys1222 [ Fri Sep 10, 2010 10:52 am ]
this will help out with wire size that you need
http://www.powerstream.com/Wire_Size.htm
Author:  postalpaul [ Fri Sep 10, 2010 2:57 pm ]
Ok if you use Ohm's law (w=E/I) 1000000/12v=83333.00 amps!?
I would say 15 amps is good enough---look at it like this I have seen many people out coyote hunting running a 1000000 candle power spotlight with a 12v cigg. lighter it is usually fused at 15 amps.
Hope this helps
Author:  brlcla [ Fri Sep 10, 2010 8:29 pm ]
Author:  duckhunter888 [ Fri Sep 10, 2010 10:20 pm ]
I am going to go with a switch panel with (6) 10amp circuits.
