It is currently Fri Feb 20, 2026 6:57 am
[ 6 posts ] |
AMP draw for handheld spotlight?
duckhunter888
Joined: Wed Jan 14, 2009 10:44 pm Posts: 828 Location: North Texas
How many amps will a 1 million candle light handheld spotlight draw on 12V plug? Looking at installing an electrical distribution switch panel with breakers and want to be sure my breaker is big enough. Thanks in advance.
_________________ Crisis defines character
| Thu Sep 09, 2010 7:19 am |
SMartin
Joined: Thu Sep 02, 2010 8:58 am Posts: 179 Location: Northwest, AR
 Re: AMP draw for handheld spotlight?
Divide the wattage of your device by the voltage of your system to calculate the amperage draw. (Watts/voltage=amperage). For example: a 55 watt light would draw a little over 4.5 amps on a 12 volt circuit. (55/12=4.583)
_________________ “Believe none of what you hear and half of what you see.”- Benjamin Franklin "Advertisements contain the only truths to be relied on in a newspaper." -Thomas Jefferson
| Thu Sep 09, 2010 1:32 pm |
keys1222
Joined: Fri Aug 21, 2009 12:42 pm Posts: 321 Location: Salina, KS
this will help out with wire size that you need http://www.powerstream.com/Wire_Size.htm
| Fri Sep 10, 2010 10:52 am |
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
Ok if you use Ohm's law (w=E/I) 1000000/12v=83333.00 amps!? I would say 15 amps is good enough---look at it like this I have seen many people out coyote hunting running a 1000000 candle power spotlight with a 12v cigg. lighter it is usually fused at 15 amps.
Hope this helps
| Fri Sep 10, 2010 2:57 pm |
brlcla
Joined: Tue Jan 13, 2009 5:11 pm Posts: 955 Location: Lake Charles, LA
| Fri Sep 10, 2010 8:29 pm |
duckhunter888
I am going to go with a switch panel with (6) 10amp circuits.
| Fri Sep 10, 2010 10:20 pm |
[ 6 posts ] |
