Full Throttle
Joined: Sun Jan 25, 2009 8:09 pm Posts: 1268 Location: North Texas
Relocating PD trim switch to grab bar
I know a few of yall have done it..... What's involved? There is a red,blue,yellow black wire running into the original switch. Anyone got any pics on how they did it? Thanks.
_________________ WC Custom 1854
Fri Sep 24, 2010 8:09 pm |
cb5331
Re: Relocating PD trim switch to grab bar
Fri Sep 24, 2010 8:35 pm |
Machine
Joined: Thu Jan 29, 2009 7:27 pm Posts: 273 Location: Malvern, Ar
if it has relays it's not necessary to upsize the wires. there wont be any load on the switch.
_________________ 1554 excel- custom MB sport totin a stage II generac temporarily 20XRD Bullet- 300X Merc
Sat Sep 25, 2010 12:16 pm |
cb5331
Sat Sep 25, 2010 2:12 pm |
J Wales
No relays on the PD trim switch...use the bigger wires.
_________________ 1848 Brother w/ 36 PD
Sat Sep 25, 2010 10:59 pm |
Machine
thats weird to not have relays with that much current better use a good switch
Sun Sep 26, 2010 7:12 am |
Full Throttle
FWIW, it's a old style winch trim. Where would I find a good switch?
Sun Sep 26, 2010 10:28 am |
J Wales
Get a switch from pd...or you can use a rocker switch off of an atv winch...they should be the same (I think tractor supply carries them). I believe they are rated for 75 amps. GT use to use relays, but had too many problems with them and changed over to these rocker switches.
Sun Sep 26, 2010 4:59 pm |
Machine
atv dealers have em in stock too.
Sun Sep 26, 2010 7:37 pm |
jus10inla
Joined: Tue Jan 13, 2009 5:55 pm Posts: 1636 Location: Baton Rouge, LA (Central)
u cant do it on winch trim without a relay. u can do it on the hydro trim tho.
ive had both
Mon Sep 27, 2010 8:44 pm |
Full Throttle
Well, I put a warn switch to the grab bar with the warn relay. 2 wires from the relay going to the winch and two wires going to the battery. When I do it this way, I cannot use the original winch trim switch (starts smoking). But as soon as I disconnect the original wires from the winch, it works flawlessly with the new switch on the grab bar....
I guess it's an either/or deal where I cannot use both?????
BTW, it's kick ass having it mounted on the grab bar!
Tue Sep 28, 2010 11:31 am |
BradS
Joined: Wed Jan 14, 2009 5:23 am Posts: 4514 Location: Lafayette, La
Any reason you cant just use a Transom Tilt Switch like from bay boat or something
Tue Sep 28, 2010 3:54 pm |
Machine
Tue Sep 28, 2010 5:03 pm |
