huntfishrace
Joined: Thu Mar 12, 2009 5:28 pm Posts: 63 Location: central La.
 one or two battries
I have a 35 GTR and was told not to run a spot light on the same battery as the motor because it would burn up the charging system. How do yall run a spot light ? Do i have to run two battries
_________________ 1546 Triton with 35 GTR
Thu Mar 26, 2009 6:14 pm |
Ace
Joined: Thu Jan 15, 2009 9:26 am Posts: 285 Location: Lafayette LA
 Re: one or two battries
I run the motor on original batt; all other accy on second. Something about the motor not charging until 2000 rpm's. I believe minimal accy usage wouldn't be too bad, but wouldn't you rather know you're getting home one evening. Remember, no rope start
_________________ Ace Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
Thu Mar 26, 2009 7:06 pm |
huntfishrace
yea getting home is important. The problem i have is i leave my boat in the water over night and not able to charge battery without removing it and bringing to camp. With my outboard i could run all weekend and keep my battery charged. Also dont want two battries in boat
Thu Mar 26, 2009 7:15 pm |
Ace
Well then take your chances that you won't use more than you can charge. Like I said, small usage at times prolly won't kill it, but the GT dudes told me to get a second batt for my lights. I run two aircraft landing lights in the front, and I have a hardhat light that I use also. Usually not together, but for froggin, we idle a lot and use the hh light alot. Don't take the chance on only one batt. Good Luck
Thu Mar 26, 2009 7:19 pm |
Ace
If you're coming to GT appreciation days, then you can talk to the FE's
Thu Mar 26, 2009 7:20 pm |
mcnemar1982
Joined: Mon Jan 19, 2009 4:03 pm Posts: 2216 Location: Walker, Louisiana
I got 2 batteries and my 23 gotta rope start!
_________________ Ideas not coupled with action never become bigger than the brain cells they occupied.
Owner DEEP SOUTH CUSTOM BOATS (225) 252-2700 Good boats ain't cheap, Cheap boats ain't good!
Thu Mar 26, 2009 7:22 pm |
POKER1
Get a lawn tractor battery for a back up.
Thu Mar 26, 2009 7:27 pm |
huntfishrace
how good will a small battery hold up just for a light
Thu Mar 26, 2009 7:30 pm |
POKER1
I have run my 36PD on a lawn tractor battery for over 18 months with no problems. Its a 425ca battery from Auto Zone. That includes using the running & HH light for several hours at a time frogging. I carry second battery up front for a spare just in case and for a second HH light. So a standard battery for the motor should be fine.
Thu Mar 26, 2009 7:37 pm |
huntfishrace
Ace i see your from Lafayette thats where i work most of the time.
Thu Mar 26, 2009 7:51 pm |
deltaduckmaster
The thing is the clutch draws 20 amps and the altanator charges 20 amps so you kinda at a stand off. I run a headlight and do fine but maybe with two you might have problems . Instead of a second bat. go to wall mart and get you a jump starter pack for 35$ and keep it in your boat never have to worry about a dead batt. and only weighs a couple pounds
Thu Mar 26, 2009 8:04 pm |
basinhunter
Joined: Tue Jan 13, 2009 6:22 pm Posts: 1642 Location: Morgan City, LA
Some of you boys think bout this shit way to much. I been running the same wal mart battery for the past 5 years on a mud motor, used two lights froggin for a couple hours many times with no problems whatsoever.
It's a fuking lawnmower engine
_________________ Pro Drive m'fers
Thu Mar 26, 2009 8:10 pm |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
Thu Mar 26, 2009 8:22 pm |
deltaduckmaster
Thu Mar 26, 2009 8:27 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
Thu Mar 26, 2009 8:37 pm |
POKER1
I would hate to be tranded too.  Thats why I carry a second. They don't weigh much and its good piece of mind since there is no pull starting this thing.
Thu Mar 26, 2009 8:48 pm |
bayouboy
Thu Mar 26, 2009 9:05 pm |
POKER1
I put it in the battery box under my extended deck where its strapped down. Same place the TM battery goes.
Thu Mar 26, 2009 9:20 pm |
basinhunter
Man I hope I never get tranded Terry, if I get tranded will you come help me? Preston, try not to get tranded
Fri Mar 27, 2009 7:26 am |
MaXXis85
All may Accessories ar off the cranking battery. Ran all duck season with my HH light on that battery. But then again I was wide open so charging is not the issue. Common sense tells you an alternater dont put out much juice at idle. Thats when you need a second battery IMO.
Fri Mar 27, 2009 8:12 am |
basinlover
Joined: Mon Mar 09, 2009 12:24 pm Posts: 279 Location: DE Jeanerette, LA.
I made something that works to get you out of a bind, get a cordless drill from Harbor freight take the battery out and hook up wires where the battery connected. You have to make a handle for the chuck side and when you crank it with the trigger pressed it will charge your battery enough to get it to start, you never have to worry about your back up battery being dead. found the info here on how to do it! http://www.zetatalk.com/energy/tengy05n.htm
_________________ There is no replacement for displacement!!!!
Fri Mar 27, 2009 9:53 am |
bayouboy
Fri Mar 27, 2009 10:44 am |
basinhunter
Fri Mar 27, 2009 10:45 am |
dead animal
Fri Mar 27, 2009 10:58 am |
POKER1
At best the motor will maintain your charged battery. Charge your battery at home every now and then is a good idea. Make sure your starting your trip with a good battery to begin with.
Fri Mar 27, 2009 11:10 am |
River
Joined: Wed Jan 14, 2009 8:34 am Posts: 1092 Location: Unaffiliated, SETX group has caused me to renounce my Texas Citizenship
Get you a squirrel and a wheel and hook that up to a small generator.
Then you won't have to worry about the charging system of the motor.
_________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the outcome of the vote."-Benjamin Franklin
Fri Mar 27, 2009 11:39 am |
basinlover
But you got to have nuts!!!
Fri Mar 27, 2009 11:40 am |
