GDSD?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=13155
Page 1 of 2
Author:  Cammander26 [ Mon Oct 18, 2010 10:39 am ]
Post subject:  GDSD?
Has anyone hunted with these in the marsh? Varable tides when going and coming back from the blinds. How the trim operate and what is involved with change elevations?
Author:  go devil 23 [ Mon Oct 18, 2010 1:45 pm ]
Post subject:  Re: GDSD?
I have a 23 gdsd and I hunt it in the marsh and it dose well. 2 guys dogs and gear 22 mph. I have no answer to your tide ? due to living in the midwest on the other hand its easy to trim the motor basically you dial the trim in and forget it on the new motors you have a quick trim lever that will lower the motor 4 to 5 inches so when you get in the bind situations you can bump and grind then lift it back to your dial in position.
Author:  Cammander26 [ Mon Oct 18, 2010 3:03 pm ]
Thanx for the info im thinking about goin with that hp and model because of its simplicity. What boat do you have it on
Author:  go devil 23 [ Tue Oct 19, 2010 9:07 am ]
I have it on a 15x46 tracker w pods to help weight and take off to get on plane. I love the motor and the customer service when calling w questions. Coco is hands down a pleasure to deal with. Have had no problems and its an easy motor to service on your own.
Author:  craig [ Tue Oct 19, 2010 9:38 am ]
If you dont mind pushpoling every time you need to back up along with having to lift it out of the water everytime you want to stop you shouldn't have any problems. Just be sure you carry a cuttin torch and pipe wrenches with you at all times in the event you need to change a prop while out in the swamp....I hear that can be some fun! :lol: :lol:
I would look at other brands that offer more user friendly options if i were you!
Author:  JIMMY W [ Tue Oct 19, 2010 9:41 am ]
Spend a little more and get something good!!At least get one with reverse ;)
Author:  Cammander26 [ Tue Oct 19, 2010 10:21 am ]
GTR 23 \ GDSD leaning more to the GTR23
Author:  BASSMASTER [ Tue Oct 19, 2010 10:29 am ]
smart move! i love my gtr 23 ! great customer service! nuetral is a gift for god!
Author:  go devil 23 [ Tue Oct 19, 2010 2:29 pm ]
Neutral = clutch problems in my book as well as electric trims nothing but problems. As for reverse if you know how to drive right who needs reverse go over it.
Author:  craig [ Tue Oct 19, 2010 2:34 pm ]
Author:  Robn1020 [ Tue Oct 19, 2010 3:10 pm ]
Author:  go devil 23 [ Tue Oct 19, 2010 3:15 pm ]
just saying I want something that dosent have alot of things that can or could go wrong yes it would be nice at times but have not really said geeeze it sure would be nice to have reverse or neutral.
Author:  cmelvin [ Tue Oct 19, 2010 4:51 pm ]
Author:  Orangefoot [ Tue Oct 19, 2010 5:59 pm ]
all MM's have neutral!!
Author:  Robn1020 [ Tue Oct 19, 2010 9:11 pm ]
Author:  mississippiduckboy [ Wed Oct 20, 2010 3:20 pm ]
As the owner of a gd i can tell you stuff does break and go out. If that has not happen to you then man your lucky, but it has for me and just about every other guy on here no matter what motor you run. I would lover reverse! A clutch wont burn up if you use it right. I have had a throttle cable break, starter go out, key switch want to stop working, and many more things, so go devil is nice but it still breaks as well.
Author:  cmelvin [ Wed Oct 20, 2010 3:59 pm ]
Author:  mississippiduckboy [ Wed Oct 20, 2010 5:15 pm ]
Awwwww..thanks
Author:  white1 [ Wed Oct 27, 2010 11:14 am ]
Author:  forever draggin [ Wed Oct 27, 2010 2:10 pm ]
Author:  OwenDickeson [ Wed Oct 27, 2010 2:37 pm ]
Author:  white1 [ Wed Oct 27, 2010 3:01 pm ]
Author:  da go get'er [ Wed Oct 27, 2010 3:56 pm ]
I run a 35GDSD at work, and one thing i recommend is that if you buy a gd brand is to keep a rope tied to the floor so that when push poling backwards you can tie the motor handle down keeping it from hanging up.
In my opinion Warren makes durable motors. As of this morning I have 484 hrs on it, I put it in the louisiana swamp nearly everyday and I can tell you they are reliable. This doesnt mean I havent had to do some work on it, I'm just saying they'll get the job done without all that fancy stuff like the other motors have. Warren has been around a long time and makes things simple for a reason. They are easier to work on and parts are less expesive.
By the way for all those who need reverse and cant push pole out,
thats what they make winches for :D
Author:  DeathMetalDukk [ Wed Oct 27, 2010 8:05 pm ]
Get ready....
Warren really doesn't make sht besides a shaft and a platform with some holes in it, and a bolt to pivot on. Briggs makes the motors, so besides a few very basic moving parts, there's nothing to a GD. Sure, they are durable. So are rocks. You like a couple of razor blades swinging around at 800 rpm's behind you, gunnel level at a busy launch with other boats around? Get something at least with neutral. Force GD to update to at least a safe standard.
I would much rather hit reverse than fight a winch and cable. That's just retarded.
Author:  DuckHunterF250 [ Wed Oct 27, 2010 8:10 pm ]
gdsd does have options, a key switch and a kill switch what else do u need :shock: :lol: :lol: :lol: :lol:
Author:  take'emgator [ Wed Oct 27, 2010 9:11 pm ]
Wait a minute, i have not heard of a clutch on a GTR going out but maybe thats just me, correect me if i'm wrong.
Author:  mississippiduckboy [ Wed Oct 27, 2010 9:40 pm ]
Author:  robertb4wd [ Wed Oct 27, 2010 9:41 pm ]
blah blah blah, They all fukin break and they all have good and bad points. I run a GDSD and when I bought mine I just wanted simple. My next one will probably have neutral and maybe reverse. That's not saying I'm unhappy. :)
Author:  autogateman [ Wed Oct 27, 2010 9:45 pm ]
Author:  robertb4wd [ Wed Oct 27, 2010 10:00 pm ]
Honestly, if were unhappy I'd sell it and get something else.
Author:  Gigafowl [ Wed Oct 27, 2010 10:17 pm ]
Author:  Gigafowl [ Wed Oct 27, 2010 10:21 pm ]
Author:  da go get'er [ Thu Oct 28, 2010 10:25 am ]
Author:  Cammander26 [ Tue Jan 18, 2011 8:07 pm ]
OK sounds good so besides the neutral and reverse, as far as going through the mud its the prop design that matters the most, the prop dosent know what is turning it rather it be a gdsd or a gtr.
Author:  craig [ Tue Jan 18, 2011 8:10 pm ]
[quote="Cammander26"]OK sounds good so besides the neutral and reverse, as far as going through the mud its the prop design that matters the most, the prop dosent know what is turning it rather it be a gdsd or a gtr.[/quote
and shaft length and shaft angle and skeg/hub resistance.
Author:  Woodiebuster [ Tue Jan 18, 2011 8:15 pm ]
cant you get gt to build longer output shafts when you buy em?
Author:  craig [ Tue Jan 18, 2011 8:16 pm ]
Author:  swamphonkey [ Tue Jan 18, 2011 8:28 pm ]
I love my GDSD But I will beat this boat to death on stumps for 2 yrs and sell it to some poor sole on craigslist. The Gt are very lite which means more spead. But GD's have been around since 75 and I'm all about hookin locals up and puttin money In back into our towns. I like the cavitation plate but nuetral doesn't mean that much. I will say Iwill never own a PD though. But my next one will pry be a GT
Author:  Gigafowl [ Tue Jan 18, 2011 8:29 pm ]
Author:  deltaduckmaster [ Tue Jan 18, 2011 8:33 pm ]
Page 1 of 2 All times are UTC - 6 hours
