Hydro Turf http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=14430 |
Author: | cbrown [ Thu Dec 09, 2010 2:03 pm ] |
Post subject: | Hydro Turf |
Guys, looking to order some Hydro Turf for the boat. Planning on buying the sheets from Gatortrax. Does anyone have pictures of their PD with the Duck Camo or plain Brown. Camo looks cool but not sure if it would look right considering the PD's have a lot of brown and black on em. If anyone has some pictures, sure would like to see the difference between the two on the PD paint. |
Author: | johnny rebel [ Thu Dec 09, 2010 4:52 pm ] |
Post subject: | Re: Hydro Turf |
Had mine for about 6 months. Dads had his for over a year. The Camo turf still looks the same as when he bought it. Got it through Gator Trax. |
Author: | DeathMetalDukk [ Thu Dec 09, 2010 4:56 pm ] |
A lot of people on here use the grey seconds from hydro turf, they're cheaper. |
Author: | cbrown [ Thu Dec 09, 2010 4:59 pm ] |
Thanks Johhny Reb. looks good. |
Author: | rickjames [ Thu Dec 16, 2010 5:35 am ] |
i used camo-toad they are in gonzales la 225-802-8579 give them a call tell them you seen on mmt they gave me a discount |
Author: | deadbird8 [ Fri Dec 24, 2010 12:36 pm ] |
Not a PD but here is the 'GT Brown'- (its really OD green no matter what Kent says). And after a little mud, both the camo, green, and grey look about the same. |
Author: | JIMMY W [ Sat Jan 01, 2011 10:43 am ] |
I am looking for someone to hire that knows what they are doing to remove mine and install some camo turf ![]() |
Author: | duckhunter888 [ Sat Jan 01, 2011 2:01 pm ] |
Author: | quackconsumer [ Sat Jan 01, 2011 4:32 pm ] |
Author: | Mmax96 [ Fri Jan 21, 2011 10:12 pm ] |
3M makes a spray adhesive remover for their spray adhesives. Heard it works well, but have not tried it myself. |
Author: | Ruddyduck [ Sat Jan 22, 2011 10:11 am ] |
I had to remove it to do some repairs and it was a brutal bich! Scraped off turf, then tried thinner, acetone, 3M remover, lost hope so I sand blasted then used a DA to sand off the tough spots. Removeing the turf and cleaning up the mess took 10X longer than fixing the boat! Really nice stuff, but I'll never use it myself. The abuse I put a hull through often requires me to get to the bottom of the boat from the inside and thats to much work!! Just my opinion! |
Author: | duckhunter888 [ Sat Jan 22, 2011 11:27 am ] |
Author: | DeathMetalDukk [ Sat Jan 22, 2011 4:46 pm ] |
I've never seen the stuff in person, but here's a thought for those who don't want to ever have to do the adhesive thing - Could you pop rivet it or put a few screws and some aluminum trim strips to hold it down, or are the sheets too flimsy and need to be adhesived? |
Author: | Mudskiff [ Sat Jan 22, 2011 4:50 pm ] |
DMD, they are a bit flimsy esp. when its hot outside. But i think that may work for some folks. ![]() |
Author: | duckhunter888 [ Sat Jan 22, 2011 5:48 pm ] |
Talking from experience if you have any chance you will need to take it up then DON'T put it down. |
Author: | Phathead [ Sat Jan 22, 2011 9:15 pm ] |
The easiest way to get it up is by using a recip saw with one of the scrapper blades. Start at an edge and have someone pull gently while you do the power scrapping. |
Author: | Tcounty [ Mon Jan 24, 2011 7:25 am ] |
Why not attach turff to floor out of the baot, then pop rivet it down. Then all you have to do is drill rivet out ,lift floor and turff out to fix bottom of boat. |
