It is currently Fri Jul 18, 2025 2:36 pm
Reply to topic  [ 11 posts ]
 Need Help!
Post Need Help!
How can you get the prop of a GDSD that is a little rusted on? im new at this and have no clue how to do it?
35GDSD Chasing 1656GD
Sun Feb 13, 2011 4:30 pm
Post Re: Need Help!
im suprised Giga aint jumped on this
Sun Feb 13, 2011 4:39 pm
MMT Moderator
Post Re: Need Help!
2x4 and you chalk it up I believe he's posted about it before...
GTB 1860 w/ 2019 GTR40XD-HO
Sun Feb 13, 2011 5:02 pm
Post Re: Need Help!
clean the rust off. coarse steel wool might work. wrap enough steel wool around a drill bit to create a somewhat snug fit in the hub of the prop. then let the drill do the work.
fyi - I don't have a surface drive and don't know how the prop attaches to the shaft on a gdsd, but just trying to give you some ideas.
Sun Feb 13, 2011 7:07 pm
Post Re: Need Help!
are you trying to remove the prop or put it on?
Sun Feb 13, 2011 7:09 pm
Post Re: Need Help!
you might have to heat the hub of the prop up w/ a tourch the pretty much just beat it off w/ a hammer . Then put a lot of never seize/pipe dope/copper kote then screw the new prop on after the threads are clean w/ a wire brush the never-seize is on.
good luck
18x48 EXTREME w/ 35GTR MARSH MELLOW XX
Sun Feb 13, 2011 9:07 pm
Post Re: Need Help!
heating prop may mean new seals.
Sun Feb 13, 2011 10:32 pm
Post Re: Need Help!
Get some dry ice..or nitrogen
Sun Feb 13, 2011 10:33 pm
Post Re: Need Help!
Was just thinking that Garrett, had to do it to my old LT but it was the only way to get the prop off, ended up replacing seals. I always use to pull the prop off and clean it about every 4-6 runs jsut to keep it clean
Sun Feb 13, 2011 10:35 pm
Post Re: Need Help!
may have to fab a piece of alum 3''x1/2''x3' with hole big enough to go over shaft at the end and bind it against prop to unscrew it. works for prodrive
Sun Feb 13, 2011 10:42 pm
Post Re: Need Help!
where u located duck slayer?
18x58 w/healthy GTR 35
"A good friend will bail you out of jail but a true friend will be sitting by you saying damn that was fun"
Mon Feb 14, 2011 2:31 pm
Users browsing this forum: No registered users and 153 guests
