OD Green Paint http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=17777 |
Author: | Bayoublackhunter [ Sat Apr 16, 2011 11:32 am ] |
Post subject: | OD Green Paint |
What's the best brand of paint and primer to use when painting a new hull? I seen that a few people used duracoat just looking for some of yall opinions, thanks in advance. |
Author: | earl33 [ Sat Apr 16, 2011 12:43 pm ] |
Post subject: | Re: OD Green Paint |
Call Lou, he can fix you up... http://www.lockstockbarrell.com/ |
Author: | cb5331 [ Sat Apr 16, 2011 12:50 pm ] |
Duralux aluminum boat paint seems to be pretty popular. Only come's in one color, but it's pretty much an olive drab. Does not require a primer which is nice... |
Author: | Bayoublackhunter [ Sat Apr 16, 2011 1:43 pm ] |
I called davidsons hardware in houma another have duck boat green,pero green, dead grass green and dark green, and its only $22 a gallon , |
Author: | UNCLE-J [ Sat Apr 16, 2011 1:47 pm ] |
Bayoublack... The Duralux is a bit more expensive, but you do NOT have to Prime.. So, with that said, it takes half the time, and you save money on primer.. |
Author: | Bayoublackhunter [ Sat Apr 16, 2011 1:56 pm ] |
they said it was Duralux , Is all of duralux's paint the same or just one kind you dont have to prime? |
Author: | UNCLE-J [ Sat Apr 16, 2011 2:08 pm ] |
They are all not the same.. You need Alum. Boat Green. |
Author: | Bayoublackhunter [ Sat Apr 16, 2011 2:10 pm ] |
Is it a good color?, I want something not too dark but not too light Sent from my Motorola_i1 using Tapatalk |
Author: | Bayoublackhunter [ Sat Apr 16, 2011 2:22 pm ] |
How much paint does it take to paint a 1854 with two coats? |
Author: | aweyerman [ Sat Apr 16, 2011 2:28 pm ] |
If I were you I would paint it tan. Tan is much much easier to hide than that old dark od green. |
Author: | cb5331 [ Sat Apr 16, 2011 2:49 pm ] |
Author: | Bayoublackhunter [ Sat Apr 16, 2011 3:26 pm ] |
Im gonna spray it so it shouldnt to bad, talk think I should buff it out sand it with a palm sander? |
Author: | aweyerman [ Sat Apr 16, 2011 3:58 pm ] |
You can clean with luma-brite. Then buy an etcher and u can skip the hard sanding. |
Author: | caddobrook [ Sat Apr 16, 2011 4:01 pm ] |
http://www.nextag.com/bottompaint/m736/seller-html That is the link on where you can get the Duralux. They have only one color of the "Aluminum Boat Paint" which is a no-primer paint-and as they put it "with a vinyl type coating". Dark Green Only. This is the M736 that some boat builders use. Geaux used it I know. Then they have three colors in the Camouflage paint- Dead Grass Green, Pirouge Green, and Duck Boat Drab. This paints requires a primer coat. They have pretty good instructions on what to do to prep and best ways to paint. You can click the links and see a color sample of all. Good luck |
Author: | Barroll [ Sun Apr 17, 2011 8:55 am ] |
Author: | T-Bubba [ Sat Apr 23, 2011 1:29 pm ] |
Do any of yall know the radio of how much thinner to add to the alum boat green to spray it? |
Author: | cb5331 [ Sat Apr 23, 2011 1:32 pm ] |
Check their website. I want to say the instructions say it is not recommended to thin, but it tells you how and what to use if you want to do it anyway. |
Author: | autogateman [ Sat Apr 23, 2011 2:01 pm ] |
DO NOT USE THE PARKERS DUCK BOAT GREEN FROM CABELAS!!!!!! The finish is soo flat on my boat it resembles a green chalkboard. everything that touches the hull leaves a white scratch |
Author: | cb5331 [ Sat Apr 23, 2011 2:06 pm ] |
When he said aluminum boat green, I was assuming he was talking about the duralux paint. If that ain't what you were talkin bout T-bub, disregard my previous post. |
