It is currently Thu Jul 17, 2025 11:18 pm
[ 8 posts ] |
stu
Joined: Wed Mar 16, 2011 2:35 pm Posts: 608 Location: Deerfield Beach FL,
 Salt
Still gathering information to purchase my first Mud Motor. Do any of you run your MM in Salt Water and have you had any problems because of it. Thanks in advance for any information.
_________________ Swomp 35 on an 1848 Alumitec Custom
Sat Apr 23, 2011 6:15 am |
Buddman
Joined: Thu Dec 09, 2010 8:16 pm Posts: 96 Location: Morgan City, LA
 Re: Salt
Just hose it down when you get back. Maybe spray some penetrating oil on the exhaust. You'll be fine. Goin get dem reds and specs?
Sat Apr 23, 2011 6:19 am |
MeatWagon
 Re: Salt
I paid a lil extra to get mine Hot Dip Galvanized and it has saved me some headache. My old longtail frame has some nice rust spots that i have had to fix but i have had it goin on 8 years and it still goin strong. X2 on the hose and oil . You never can have too much oil on your motor.
_________________ SENT VIA HOOT OWL!
I drive a Godevil and don't give a shit about your message!!!
MeatWagon GoDevil 35 Surface Drive on a 13x60 MaxCraft AIRBOAT HULL!
Sat Apr 23, 2011 6:48 am |
WestEndAngler
MMT Moderator
Joined: Thu Mar 05, 2009 9:11 am Posts: 9143 Location: Houston | Surfside
 Re: Salt
I run mine almost every weekend in saltwater she is running like a bat out of hell! I do spray down the engine and have built up a good layer of Corrosion-X
_________________ GTB 1860 w/ 2019 GTR40XD-HO
Sat Apr 23, 2011 7:20 am |
robertb4wd
Joined: Sat Jul 18, 2009 7:18 pm Posts: 1501 Location: Bridge City, Texas
 Re: Salt
The GDSD is available in galvanized. I kept mine coated with WD40. The GTR frame and lower unit is aluminum and the mounting bracket is galvanized.
_________________ 1754 Gatortail Extreme / 35 GTR
Sun Apr 24, 2011 11:14 pm |
stu
 Re: Salt
Thanks for the advice. Sounds like it's not a problem if you stay after it. Thanks again for letting me in on your experience.
Mon Apr 25, 2011 4:55 am |
swamprat11
 Re: Salt
you can about anything in the salt, but you GOTTA clean and oil it good afterwards.. invest in a couple of big cans of cheap penetrating lube and use them you will be fine. but if you can get galv you would be better off
Mon Apr 25, 2011 2:16 pm |
robertb4wd
 Re: Salt
The bottom of the skeg will rust, just keep it coated. Make sure you use nickel cease on the prop shaft. Makes it easier to get the prop off.
Mon Apr 25, 2011 8:30 pm |
[ 8 posts ] |
Users browsing this forum: Google [Bot] and 81 guests |
