It is currently Sat Feb 14, 2026 10:29 am
Reply to topic  [ 15 posts ]
 Prodrive rib nuts
Post Prodrive rib nuts
Anyone know where I can get some of those rib nuts that prodrive puts in there cross bracing for the seat to bolt in? Also, what is the correct name for them?
Tue Apr 28, 2009 12:04 pm
Post Re: Prodrive rib nuts
http://www.fastenermart.com/html/600220000040.html
1948 Aucion's SS Edition Bateau with a stock 35GTR
Tue Apr 28, 2009 12:20 pm
riv-nut or nutsert
fastenal.com
1660 Rhino High-Side with center console
90/65 Mercury 2 stroke Outboard jet pump
Run shallow, run loud.
Tue Apr 28, 2009 12:37 pm
thanks, another retarded question, but about what size do they use? Now that I have found them I have also found out that there is a huge selection of them to pick from.
Tue Apr 28, 2009 12:44 pm
Shank length plays into the mix also.. You need to know how think the material is that your putting them in.. The PD riv-nuts are either 1/4x20 or 5/16x18 if I remember right..
"I just want silence. Jesus, it doesn't mean I don't like you. It just means right now, I like silence more."
Tue Apr 28, 2009 1:40 pm
You can get them at Menards along with the tool in the same isle as the rivits
Tue Apr 28, 2009 1:46 pm
ProDrive rib nuts..... is that kinda like Gatortail Chin Nuts????? :mrgreen:
24x60 Dual Prodrives
Tue Apr 28, 2009 1:55 pm
Tue Apr 28, 2009 2:17 pm
17x48 extreme stage 2 GTR
Tue Apr 28, 2009 4:49 pm
Paul you can get them from godevil with the tool.
Tue Apr 28, 2009 5:19 pm
You can find the "kits" on ebay. Contains the tool and several sizes of the fasteners.
Guy at the fastener store here in Tyler showed me how to set them without a tool. It can be done but the tool makes it a whole lot easier.
OneBigAssMistakeAmerica
Tue Apr 28, 2009 5:33 pm
When I bought my Quickset blind it came with some rivnuts and a "tool" to set them. The tool was a 1/4 20 bolt and a nut. Thread the nut on the bolt, then the rivnut.
1754 PD w/ 36 PD HTT & FPR
Wed Apr 29, 2009 12:55 am
http://www.rivetnuttool.com/
Sat May 02, 2009 4:33 pm
All the PD boats I had, were 3/8x16 riv nuts.
Cardinal tool has a fairly cheap tool for installing them, mine cost $65 a couple years ago. You can get the riv-nuts at
Tool: (bottom one!)
Bought plain stainless allen head bolts and the black "wing-nut" caps that snap over the bolts at the local true value hardware.
Wed May 06, 2009 7:00 am
I got a kit at Home Depot. It would not install the 3/8 Riv nuts but had 3 smaller attachments. $19 if I remember right.
Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Wed May 06, 2009 2:27 pm
