charging battery
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=188
Author:  med [ Wed Jan 21, 2009 9:02 pm ]
Post subject:  charging battery
is it ok to hook the charger up on the battery with it still connected to the engine or do you need to undo connections before charging?
Author:  LaBirdman [ Thu Jan 22, 2009 6:07 am ]
Post subject:  Re: charging battery
Never unhooked mine to charge it. Course I charged mine in the daylight on a clear day.
Author:  River [ Thu Jan 22, 2009 7:14 am ]
Author:  med [ Thu Jan 22, 2009 12:26 pm ]
thanks. just wanted to make sure that i wouldnt fry anything.
Author:  bayouboy [ Fri Jan 23, 2009 3:37 am ]
The 12v battery charger is really not that much different then the charging system on the engine, both have a built in 12 vot voltage regulator which shuts down the charging process once the battery reaches full charge. the only thing you might be changing are the amps. that being said it will not hurt anything in a 12 volt system.
