PaulDarensbourg
Joined: Fri Jan 23, 2009 11:07 am Posts: 602 Location: Baton Rouge
 Prodrive rib nuts
Anyone know where I can get some of those rib nuts that prodrive puts in there cross bracing for the seat to bolt in? Also, what is the correct name for them?
| Tue Apr 28, 2009 12:04 pm |
SwampSnyper
Joined: Tue Jan 13, 2009 8:43 pm Posts: 823 Location: SORRENTO, LA
 Re: Prodrive rib nuts
_________________ 1948 Aucion's SS Edition Bateau with a stock 35GTR
| Tue Apr 28, 2009 12:20 pm |
Mudgun
Joined: Wed Jan 14, 2009 12:24 pm Posts: 746 Location: Here Be Rocks VA
riv-nut or nutsert
fastenal.com
_________________ 1660 Rhino High-Side with center console 90/65 Mercury 2 stroke Outboard jet pump Run shallow, run loud.
| Tue Apr 28, 2009 12:37 pm |
PaulDarensbourg
thanks, another retarded question, but about what size do they use? Now that I have found them I have also found out that there is a huge selection of them to pick from.
| Tue Apr 28, 2009 12:44 pm |
Rail
Shank length plays into the mix also.. You need to know how think the material is that your putting them in.. The PD riv-nuts are either 1/4x20 or 5/16x18 if I remember right..
_________________ "I just want silence. Jesus, it doesn't mean I don't like you. It just means right now, I like silence more."
| Tue Apr 28, 2009 1:40 pm |
mudd
Joined: Wed Jan 14, 2009 5:44 pm Posts: 443 Location: Wisconsin
You can get them at Menards along with the tool in the same isle as the rivits
_________________ THE, FIRST and ONLY MMT Member of the Year!
| Tue Apr 28, 2009 1:46 pm |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
ProDrive rib nuts..... is that kinda like Gatortail Chin Nuts?????
_________________ 24x60 Dual Prodrives
| Tue Apr 28, 2009 1:55 pm |
PaulDarensbourg
| Tue Apr 28, 2009 2:17 pm |
deltaduckmaster
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
| Tue Apr 28, 2009 4:49 pm |
benelliman
Joined: Wed Jan 14, 2009 10:54 am Posts: 532 Location: Livonia, La.
Paul you can get them from godevil with the tool.
| Tue Apr 28, 2009 5:19 pm |
LOWRY
You can find the "kits" on ebay. Contains the tool and several sizes of the fasteners.
Guy at the fastener store here in Tyler showed me how to set them without a tool. It can be done but the tool makes it a whole lot easier.
_________________ OneBigAssMistakeAmerica
| Tue Apr 28, 2009 5:33 pm |
duckfire
When I bought my Quickset blind it came with some rivnuts and a "tool" to set them. The tool was a 1/4 20 bolt and a nut. Thread the nut on the bolt, then the rivnut.
_________________ 1754 PD w/ 36 PD HTT & FPR
| Wed Apr 29, 2009 12:55 am |
Jim1648
Joined: Sat May 02, 2009 4:24 pm Posts: 115 Location: Michigan
| Sat May 02, 2009 4:33 pm |
RC
Joined: Tue Jan 13, 2009 8:01 pm Posts: 139 Location: Northern Indiana
All the PD boats I had, were 3/8x16 riv nuts. Cardinal tool has a fairly cheap tool for installing them, mine cost $65 a couple years ago. You can get the riv-nuts at
Tool: (bottom one!)
Bought plain stainless allen head bolts and the black "wing-nut" caps that snap over the bolts at the local true value hardware.
| Wed May 06, 2009 7:00 am |
balloon-knot
Joined: Wed Jan 14, 2009 9:05 am Posts: 398 Location: Prairie du Chien, WI
I got a kit at Home Depot. It would not install the 3/8 Riv nuts but had 3 smaller attachments. $19 if I remember right.
_________________ Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
| Wed May 06, 2009 2:27 pm |
