It is currently Sat Feb 14, 2026 9:00 am
[ 2 posts ] |
robicheaux
Joined: Tue Apr 28, 2009 11:45 am Posts: 15 Location: Franklin LA
 PD prop
I have a 25pd , bought it used and the guy said he put a 32hp prop on it. On a 14x48 boat by my self top speed is around 23mph. what advantages if any am i getting from that prop? Should i be getting more top speed? Should i put the 25/27 hp prop back on it? RPM in water is around 3980 to 4000.
| Thu May 07, 2009 9:48 am |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: PD prop
Try running both props in the same area under the same conditions. You will never know until you try it. Good luck and post the difference's between the two.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
| Thu May 07, 2009 10:53 am |
[ 2 posts ] |
