| gt trim fluid.. http://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=2003 |
| Author: | darrel from meraux [ Sat May 09, 2009 5:08 pm ] |
| Post subject: | gt trim fluid.. |
Anyone know how to change the hydrolic fluid in a gt? any other maintance issues aside for grese i should do? |
| Author: | deltaduckmaster [ Sat May 09, 2009 5:29 pm ] |
| Post subject: | Re: gt trim fluid.. |
| Author: | darrel from meraux [ Sat May 09, 2009 5:31 pm ] |
no, not for the reverse, for the trim.. |
| Author: | deltaduckmaster [ Sat May 09, 2009 5:34 pm ] |
not a clue |
| Author: | JPH [ Sat May 09, 2009 8:19 pm ] |
Take the cover off where the trim switch is attached. You will see a couple of countersunk allen head screws in the trim box mechanism. Pull the one on the front left top i believe and fill there. |
| Author: | dog walker [ Sat May 09, 2009 8:27 pm ] |
Hey DFM if you go to the GT site and go to the motor page at the bottom you can download a copy of the owners manual and they have a detailed description of how to change the fluid. |
| Author: | darrel from meraux [ Sat May 09, 2009 9:09 pm ] |
Thanks eddie, i have the original that came w/ the motor but it dont have anything about that, i must be missing a page.. |
| Author: | darrel from meraux [ Sat May 09, 2009 10:48 pm ] |
you know how often to change this trim fluid? it doesent say in the manual |
| Author: | dog walker [ Sat May 09, 2009 11:44 pm ] |
I've never changed it,I do not have a leak or anything so its fine. |
| Author: | HuntingRDR [ Sun May 10, 2009 12:43 pm ] |
I just changed mine yesterday. Look up under the plastic cover where the toggle switches are. There are 2 nuts on each side of the cover, remove those. Pull the plastic cover up just enough to get to the other bolt It is about 7inches and goes from one side of the cover to the other. Unscrew it and pull it out. This will let your actuator come out. Pull it down, and unscrew the allen head screw on the front of the actuator. That is your filler hole. Put the oil in there. Although in the back of the manual it says to retract/extract the actuator some when filling. I suggest reading it before. |
| Author: | darrel from meraux [ Sun May 10, 2009 7:13 pm ] |
how often should i change this? i dont have a leak or anything, just want to make sure it's not neglected. |
| Author: | dog walker [ Sun May 10, 2009 7:21 pm ] |
You know Darrel I don't know its the last thing that I think about,I check it out for leaks and what not but as long as it holds the motor in the position where I set it and doesn't bleed down its good. Now having said that it will go out this week and I'll be running in dragging and hitting everything back to the truck. |
| Author: | MaXXis85 [ Mon May 11, 2009 7:00 am ] |
Just run it. If it works, and no leaks are present there shouldnt be an issue. I dont see the trim ram gettign hot enough to ruin the fluid that is in the resivoir! |
| Author: | JBREAUX [ Mon May 11, 2009 7:04 am ] |
if it ain't broke don't break it |
| Author: | MaXXis85 [ Mon May 11, 2009 7:13 am ] |
| Author: | JBREAUX [ Mon May 11, 2009 8:37 am ] |
nah I just know if I would mess with my trim fluid I would end up f'n it all up lol |
| Author: | dog walker [ Mon May 11, 2009 11:52 am ] |
| Author: | BROOKS [ Mon May 11, 2009 8:50 pm ] |
| Author: | cut'em94 [ Tue Nov 17, 2020 7:41 am ] |
Since there is no information on the web on how to actually do maintenance on these Parker Trim actuators, I took some time and called the company and they gave me their very limited information on how to change out these motors on the actuator and fill the them with hydraulic oil. Pretty simple procedure. See pictures below |
| Author: | cut'em94 [ Tue Nov 17, 2020 7:44 am ] |
Part 2 of 4 Trim Procedure |
Part 3 of 4 Trim Procedure |
| Author: | cut'em94 [ Tue Nov 17, 2020 7:45 am ] |
Part 4 of 4 Trim Procedure |
