It is currently Thu Jul 17, 2025 7:25 pm
Reply to topic  [ 11 posts ]
 Throttle Conversion
Post Throttle Conversion
Has anyone converted the standard throttle on a long tail to a squeeze type typically found on surface drives? I'm thinking that this would make it easier when navigating through tight turns as well as safer in the case of losing your balance. Where can I find a squeeze type that I could install? If there are any reasons I should not please let me know.
Fri Jul 29, 2011 6:41 am
Post Re: Throttle Conversion
Nope, it's impossible. Can't be done. Don't even try it.
Fri Jul 29, 2011 7:32 am
Fri Jul 29, 2011 7:50 am
If it's an MB, it'll probably void the warranty.
Fri Jul 29, 2011 7:52 am
Sold my Uncle-J and my PD so Fuc* Y'all!!!!!.
"THE EDGE: There is no honest way to explain it because, the only ones who know where it is have gone over. The others... the living, are those who've pushed their control as far as they felt they could handle and then pulled back or slowed down........BUT the edge is still out there...."
Fri Jul 29, 2011 9:06 am
Guess I'll just try his ol lady instead...
Fri Jul 29, 2011 12:04 pm
Fri Jul 29, 2011 12:20 pm
viewtopic.php?f=64&t=20446
there you go....
Fri Jul 29, 2011 1:19 pm
Not sure if it is the same type you're looking for. I went around to Motor Cycle shops and the guy sent me to see his brother that owned a lawnmower shop. Anway I got a brake or clutch lever and cable from him for free. No idea what it was off of some tillers have squeze type levers on them. Hit the lawnmower and cycle shops the minibike is the size you need. I also added a return spring so it would go back to idle and not stay at half throttle.
SS
Fri Jul 29, 2011 6:33 pm
Put yer face in the myrtles.
Fri Jul 29, 2011 7:05 pm
Mon Aug 01, 2011 2:46 pm
Users browsing this forum: No registered users and 104 guests
