It is currently Wed Jul 16, 2025 11:31 am
Reply to topic  [ 13 posts ]
 GT Trim Question
Post GT Trim Question
GT has been sitting up for about 4 weeks so I went out yesterday to start it up. Motor started fine, idled, reversed, everything worked. Went ahead and trimmed up from trailering bracket and then trimmed it back down. During down trim, it stopped working. Tried several more times and got nothing. Shut motor off, pulled switch cover (new one on tiller), to see if any wires had come loose. All connected and no corrosion. So I tried to trim again, nothing. Turned key to on position and switched clutch from start to forward to see if it was clicking at back of motor. It was intermittent at best. Would flip switch several times before I could get it to engage. Trim still won't work. Any Ideas?? :?: :?: :?: :?:
Don't know of any fuses between either of them. Also, when GT put on the new control box, they had to replace the diodes in the motor (kept blowing fuses).
Ace
Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
Wed Aug 03, 2011 3:08 pm
Post Re: GT Trim Question
Make sure the nut is tight on that lil box on the side of the engine. Mine seems to loosen up at times
1754 Xtreme 35 GTR Stage 1
Wed Aug 03, 2011 3:30 pm
How are you liking that Cajun Performance hull ???
Wed Aug 03, 2011 3:37 pm
Howard I'm sure you did but check your battery connections and the charge on the battery. Is the trim not working in both directions?
Wed Aug 03, 2011 3:41 pm
Ace
Wed Aug 03, 2011 4:20 pm
Ace
Ace
Wed Aug 03, 2011 4:21 pm
Wed Aug 03, 2011 4:22 pm
Yes if the motor is starting you should be good. On the side of the engine by the starter there is a small box that has a piece of plate on it going to the starter I think and a wire going to it. If the nut is loose or there is a bad connection there that will keep your trim from working. Check that out,I've had it happen and just had to tighten it up.
Wed Aug 03, 2011 5:56 pm
I just had this same problem and it was a bad relay. The relays are either in your battery box or on side of motor if you open these up , I had all kinds of corrosion in there so I swapped em out and cleaned the connections in the plug, packed em full of dielectric grease and it works like a champ now.
Wed Apr 04, 2012 4:11 pm
Also their is a fuse in that line that wouldn't hurt to check but I would guess corrosion in a connector.
Wed Apr 04, 2012 4:12 pm
If the solenoids are clicking on the up and down side check the voltage on the two wires going to the trim motor. With the trim switch depressed up or down you should have 12 volts on one wire and the other should be grounded. Flip the switch in the opposite direction and the voltage and ground should switch to the opposite wires as well. If you have 12 volts and a ground and the trim motor does not run you have a issue with the trim motor, worn or dirty brushes.
Wed Apr 04, 2012 9:02 pm
Ace has the upgraded control panel and they elleminated the relays.
Thu Apr 05, 2012 7:26 am
Users browsing this forum: No registered users and 126 guests
